Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Getting close First Test Run
Old 03-01-2005, 07:52 AM   #1
Talking Getting close First Test Run
Well i took it out for a test run and found some problems i need to fix. The first onn being the steering arm from the servo is not doing a good job of turning , i think i need to make one that has a z bend in it. next problem was when it gets bound up it stripped out the spur gear in the tranny. Those are fixed for now and i am trying it out with 2 shocks at each end, even though it takes away from lots of flex. I may go back to the single spring in the rear . That worked really well and the spring width did maintain staibility, much better that you would think. I'm not sure how putting shocks with out springs can benifit the set up. take a look and tell me what you think. All input is helpful
EJEEP is offline   Reply With Quote
Old 03-01-2005, 07:53 AM   #2
Thumbs up some more
what do you think?
Old 03-01-2005, 09:26 AM   #3
I think it needs to be lowered. Idealy you would like yoursuspension links parallel to the ground. This hels to reduce axle steer and inprove suspension response. Center clearance of around 4.5 -5.5 inches seems to be what most people are running. Just my 2 cents.
stlcrawler is offline   Reply With Quote
Old 03-01-2005, 10:01 AM   #4
wheel base, wheel base, wheel base!!!!!
DirkDigler is offline   Reply With Quote
Old 03-01-2005, 10:08 AM   #5
MODERATOR™
EeePee's Avatar
Try moving your shocks inboard towards the tranny. You'll lower it, and lengthen it at the same time, and you will gain some articulation back.
EeePee is offline   Reply With Quote
Old 03-01-2005, 11:45 AM   #6
just basically what everyone else said. it needs to be lowered and lengthened for stability. moving the top of the shocks in ward to the center will solve bothe these problems and give you alot more articulation.
mike is offline   Reply With Quote
Old 03-01-2005, 03:16 PM   #7
Default Wheelbase
The wheel base is 16" and i tried the shocks layed forward but i think i'm getting some bind out of the four link. What wheelbase do i need to shoot for? how do i stop the binding if the link arms.
Old 03-01-2005, 03:21 PM   #8
2006 2.2 National Champ
BENDER's Avatar
Probably about 17" for WB, with Kongs, and lowering ride height will "flatten links out" so they're more parallel to the ground. Just lowering it will fix a lot for you.
BENDER is offline   Reply With Quote
Old 03-01-2005, 03:44 PM   #9
Diggin' the new SCX10 II!
badger's Avatar
There is no way that this is at 16" wb. How are you measuring it?
badger is offline   Reply With Quote
Old 03-01-2005, 03:44 PM   #10
I "call" on the wheel base. NO way that thing has a 16 inch wb.
It looks like 14 or 15 inches to me.
Measure again! seriously.....maybe your ruler is wrong!!!
With Kongs...you'll want 17 inches minumum!
Old 03-01-2005, 03:46 PM   #11
Haha
Badger
we must have been eyeballing and posting at the exact same time.....crying "bullshiat"!!!!!!
If you take that ruler in the picture and visually put it horizontally, the wheel base looks like it would land in the 12 inch range. Hell.....my pecker is almost that long!!!!!
Old 03-01-2005, 03:49 PM   #12
badger's Avatar
Originally Posted by WannaBeDigler
Haha
Badger
Yeah no kidding! Although I could only measure a xmod's wheel bases! :-(
Old 03-01-2005, 06:10 PM   #13
Your sick! but i agree lower that thing!
broncotxt is offline   Reply With Quote
Old 03-01-2005, 08:19 PM   #14
looks good i agree you need to remeasure the wheel base and lower it
bubbacheechee is offline   Reply With Quote
Old 03-01-2005, 09:32 PM   #15
Red face Wheelbase
My bad the 16"WB is without the shocks on the damn thing i now see where i'm messing up. I will make longer links to strech it to 17" or so, thanks for the input, but i can only carry 4 or 5 of you on my back at a time when you jump on me for f-ing up!!! (LOL) I'LL KEEP WORKING.But so far i'm on the right path . Can i hear an amen
lol More to come
Old 03-01-2005, 09:48 PM   #16
badger's Avatar
lol More to come
Amen! At least you understand where you F'ed up!
Dirk still does not get it!
Old 03-02-2005, 12:27 AM   #17
My next question is how the heck did you strip out the spur gear!? You better check your gear mesh befor you run it again.
Old 03-02-2005, 09:11 AM   #18
Right!.....or should I say, Wrong!
Oh well........
I hate you all!
