05-01-2007, 04:59 PM | #1 |
Rock Stacker Join Date: Apr 2007 Location: Nor Cal
| What to do?
I just picked up all these parts for a screaming deal- Intigy 55t motor Tekin Rebel 2 SC Hitec 265 servo Tranny and drivelines Airtronincs Control 4 TXT axles 2 Batteries New rims and tires And one beat to hell crawling frame. Im new to RC crawling, i had the big nylint crawler, but alas it broke! But i got all these parts and want to build a decent rig. It moves in its current form but the suspension links are crappy and poorly designed. What kind of frame/suspesnion would you recommend as im not ready to fabricate my own just yet. Thanks. |
05-01-2007, 06:29 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: akron
whats wrong with the tuber i would just fix that it looks pretty nice if the links are that bad i would just make new ones and fix what you have looks like a killer start
05-01-2007, 07:53 PM | #3 |
Well the suspension binds and the links hit the shocks. If there was more of the original frame left it would be ok, but what is left is half-a** soldered and JB welded!
05-01-2007, 08:14 PM | #4 |
I would suggest Bender's SW2 chassis. |
05-01-2007, 09:19 PM | #5 |
Can you go to a 16" WB with the SW2? Thats where it sits currently sits and looks good. It seems most are running that chassis at 14" and i think it would put the tires a little to close together.
05-01-2007, 10:58 PM | #6 |
Bender ran a super with the SW2, using clod axles with an 18" wheelbase. Adding a tranny and drivelines shouldn't be much of a deal. Search "delrinator" in the clod forum.
05-04-2007, 10:21 AM | #7 |
Well i disassembled it today and the frame is history. I like the SW2 chassis but there is no provision for the stock tranny. The crawl ratio was fine before i took it apart, so i would like to keep the tranny instead of swapping to a stampede or R2. The steering servo isnt very strong so i would like to save the cash for that anyway. i tried searching ebay for stock chassis, but none available right now. Looks like i may have to build my own after all.
