Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Txt-1 and Juggernaut
Thread: advantage of an e-maxx tranny
Old 06-20-2004, 03:47 AM   #1
Default advantage of an e-maxx tranny
hi,
is there any advantage to use an e-maxx tranny instead of the original txt-1 tranny ?!? I aks because I can get a cheap e-maxx trannny.
Is the e-maxx tranny as big as the txt-1 ?
BadBoy is offline   Reply With Quote
Old 06-21-2004, 12:35 PM   #2
Default Re: advantage of an e-maxx tranny
I think they are used because you can change the spur gear. Which gives you more gear ratio options. But I'm not sure
rckjeep is offline   Reply With Quote
Old 06-22-2004, 12:46 PM   #3
That Was Totally Ninja!
rbgerrish's Avatar
Emaxx trannies are easier to gear than the TXT tranny- you have the option of using 32 or 48 pitch pinions. Also, the Emaxx tranny is a 2 speed, which is nice!
ryan
rbgerrish is offline   Reply With Quote
Old 06-22-2004, 02:40 PM   #4
ok... thanks...
Old 06-22-2004, 05:28 PM   #5
RIP Buster
badger's Avatar
ryan
I thought most people with the Emaxx tranny that crawl lock it out only to use the first gear, because it has so much slop in it?
badger is online now   Reply With Quote
Old 06-25-2004, 10:07 AM   #6
It's also a tad "shorter". Another thing I like about it is that you can make brakets for it to mount anywhere or anyway you like. You are somewhat limited to how you can mount the TXT tranny.
DirkDigler is offline   Reply With Quote
