link relocation help well, i had a buddy fab a servo mount to move the servo to the top of the front axle. And finally moved the links to the top of the front axle, getting rid of the damn skidplate. Now, the problem is the back, im not running 4ws.....but i dont know where to put that link to lock the rear wheels from turning. Any help/pics would be great. |
Re: link relocation help I"m trying to figure that out as well. I think what I'm going to do is make a drag link that attachs to the mount that holds your susp. links on the axle. Make a small extension piece that bolts to the grey mount and have it stick out over the tie-rod them make a drag link and tie-rods like this: http://www.rccrawler.com/article11.h...=0&thold=0 and attach it on top of your tie-rod to steering knuckle mount. |
Re: link relocation help I made a drag link and tie rod. I hooked up a servo on the rear and attached the tie rod and drag link that I made. I then took the steering servo off and bolted the drag link to the rearward most bolt that holds the top diff cover on. This locks out the rear and the big benefit is that you can easily bolt on the servo, connect the drag link and you have 4ws in about 2 minutes. |
Re: link relocation help quik four wheel steering ?. When you need to make a tight turn w/4ws you turn the front, then switch to the rear and turn the rear. Will the front hold it's turn? Or Rear for that matter? The whole thing kinda confusses me. |
Re: link relocation help no no no. My method gives you a lock out OR 4 wheel steering with only having to move a couple of bolts. In competition, some scoring penalizes for 4ws, so I made a set up that allows me to easily disconnect the 4ws... and with one bolt, converts to a lock out. Make sense? |
Re: link relocation help Quote:
Re: link relocation help ive just made a drag link to one of top of mounts, screw a ball there and connect a drag link, tommorow ill post pics, cause my sister took digicam with her, its easy and works!! |
http://www.rccrawler.com/article2.html |
Re: link relocation help I locked out the rear using the factory draglink and tierod. I just used the vertical screw on top of the diff that hold the top case on. It has hald up fine and the screw is plenty long enough. You dont have to buy or fab anything, just adjust the ball ends so the tires track in the correct direction. |
http://rc.badgerracing.com/albums/tx...7093.sized.jpg Here are more pictures. http://rc.badgerracing.com/modules.p...view_album.php |
Re: link relocation help Oh my god! Stop posting those ugly things!!!! :lol: |
Not quite as bad as you though... with your mug shot all over the Net! :twisted: |
Re: link relocation help Yeah. and my mug shot is the only thing more grusome than my servo mounts!!!! :flipoff: |
LMAO! |
Re: link relocation help here is a burly as hell pic of our west coast crawler style servo/link mounts. :flipoff: http://img59.exs.cx/img59/3356/crawlersam.jpg |
Re: link relocation help I was looking for a "burly" picture and didn't see it I do see the blury pic though :lol: |
Re: link relocation help im on my other computer and i can down size my bubble ass pic. lol ill have to fix it later hahah :flipoff: |
