Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Txt-1 and Juggernaut
Thread: Pics of servo mounts. Lets see'em!
Old 06-22-2004, 06:55 PM   #1
Default Pics of servo mounts. Lets see'em!
I've tried to find some different ideas and only found one example.
http://www.rccrawler.com/postt937.html
So Let's have everyone who can take some quik pics. Some pics of just the servo mount and some pics mounted would be great.
Since no body make them in the USA and I can't find any pics of the MTPA ones.
rckjeep is offline   Reply With Quote
Old 06-23-2004, 10:42 AM   #2
Default Re: Pics of servo mounts. Lets see'em!
I made a simple mount utilizing a piece of 90 degree 1/8 aluminum trimmed to fit around the servo, and secured to the axle with two 3mm bolts.
Joe
kona_joe is offline   Reply With Quote
Old 06-23-2004, 10:56 AM   #3
I made some using the stock axle guard:
DCLXVI is offline   Reply With Quote
Old 06-23-2004, 11:33 AM   #4
Nice work guys. Keep'em coming people.
Joe, I especially like your idea.
Old 06-23-2004, 12:53 PM   #5
This is how it looks mounted:
Old 06-24-2004, 08:17 AM   #6
hi,
I mount my servo for maximum of clearance on the axle...
BadBoy is offline   Reply With Quote
Old 06-25-2004, 04:20 PM   #7
RIP Buster
badger's Avatar
Bad Boy, nice camera! Those pics are so colorful and clear they almost look fake! I would get into the porn industry if I had a camera like that!
I finnaly got my F'ing TXT back from the machine shop (he was sopposed to be making me a custom skid plate). He had it for almost 6 weeks and did NOTHING with it. Well at least I got some aluminum out of him.
I will hopefully make some good progress putting it back together this weekend, so I will post picks when I can.
-Badger
badger is offline   Reply With Quote
Old 06-25-2004, 05:47 PM   #8
Badger I made a simple skid plate in like five minutes. I'll make another if you want.
Old 06-26-2004, 01:13 AM   #9
hmm... porn industry... first I must ask my girlfrind
look here is my home made skid plate (pic skid0 - skid4)
http://home.arcor.de/pflanzenoel-statt-diesel/txt/
Old 06-28-2004, 11:13 AM   #10
RIP Buster
badger's Avatar
rckjeep,
Thanks but I am not working with a stock TXT chassis any more. I cut about an inch off the bottom center section.
I will let you know how bad mine turns out (I suck at fabrication) and maybe you can help me then. Thanks for the offer.
Badboy,
How do you make the skid plate look so nice around the edges? What do you use to cut and bend the aluminum?
All I have is a vise and a dremmel to fabricate shit.
-Badger
Old 06-28-2004, 11:41 AM   #11
a friend has a factory where I can cut, bend, mill and turn the aluminium...
Old 06-28-2004, 12:07 PM   #12
RIP Buster
badger's Avatar
That must be nice. My friend does custom aluminum stuff and it sat for 6 weeks in his shop. Now I get to try and make one
Old 06-28-2004, 03:37 PM   #13
Badger, just give me the measurements and I"ll make one. I've got my TXt here at work so I can use that for reference. Let me know.
Old 06-28-2004, 10:14 PM   #14
I finally dug up the pictures I took from when I had the MTPA Mighty Mounts installed. I really liked them, but I decided to move the servos back out front so that I could reposition my lower suspension links.
schlabinski is offline   Reply With Quote
Old 06-29-2004, 11:22 AM   #15
Well here's some pics of my shi@t
http://www.imagestation.com/album/pi...?id=4286392553
Old 06-29-2004, 12:27 PM   #16
RIP Buster
badger's Avatar
I forgot that I already had pictures of my servo mounts that were made by Dirk.
And you can always go to http://rc.badgerracing.com/modules.p...php&page=1
and click on any picture twice to get a huge blow up of it.
Old 08-19-2004, 03:17 PM   #17
RIP Buster
badger's Avatar
The front servo mount in the previous post worked well until it cracked the plastic where the screws go into the case.
I made this new mount to relocate the servo out from in the middle where is was getting hit by rocks alot. This was just a quick fix which turned out to be a extremly strong mount. It is hard to explain to I will let the pictures do the talking.
This is the only place I used servo tape on the bottom of the servo touching the top of the axel housing. There was really no room anywhere else to use the thick servo tape.
The servo does not budge at all. I don't know if this will be good or bad.
For huge close up shots go here and click on the photo to get the full size image.
http://rc.badgerracing.com/modules.p...php&page=3
Old 08-19-2004, 06:42 PM   #18
TEAM MODERATOR
EeePee's Avatar
Badger, does the servo hit the frame when you get a lot of articulation?
When I mock up a mount there, the servo hits the frame.
I guess I could hack off that lower "frame rail"...
EeePee is online now   Reply With Quote
Old 08-19-2004, 08:46 PM   #19
RocJoc's Avatar
Location: crawlin with out the bullshit of someone else's rules
whats holding the bottom of the servo look like two sidedtape just curious looks good though
RocJoc is offline   Reply With Quote
Old 08-19-2004, 09:43 PM   #20
Nomercy's Avatar
dosent look like its going to go any where, it looks jamed in aginst the knuckle. did you have to trim for that.
Nomercy is offline   Reply With Quote
