![]() | #61 |
TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
Pretty slick set up there diesel. Are you still leaning towards link mounted shocks?
![]() | #62 |
not really sure yet. could run a normal 4" shock but it'd be laid down quite a bit. i'd have to limit them a lot.
![]() | #63 |
Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
That is where I had my servo mounted on my 2.2 TXT. Worked out really well, as low as you can go, basicly. Your mount looks better made than my homemade jobby. ![]() ![]() |
![]() | #64 |
Well last night i got the upper links done (thanks frankyrizzo) and mounted. Now i can start on shock setup. At ride height its 3" from upper shock mount to lower shock mount. So i could run a 4" shock, if it were heavily limited.. Ill throw together some mockups tonight and see what i need to do.
![]() | #65 |
well im pretty sure ive figured out the shocks... on the 2.2 blackjacks we run 3.5" shocks with some internal limiting, on this im running 4" Ti nitride maxx shocks with a lot of internal limiting. 11/16" of fuel tubing inside the the shack actually. not positive about the springs yet as these were just something i had laying around. if it looks like the shocks are tilting outward at the top, they are. i wasnt sure about it when i first bolted everything up but it actually travels very smoothly, im really happy with it. pics. let me know what you think. oh and thats my brother ****in around in the background in that one pic. |
![]() | #66 |
The shocks aren't laid down too much, they look good mounted like that.
![]() | #67 |
Man im totally stoked about this rig!! The suspension is sooo smooth! I showed frankyrizzo and its now got the official sin city stamp of approval.
![]() | #68 |
TEAM RCC Join Date: Oct 2005 Location: THE ALIEN WORKSHOP
Looks good Scott ![]() I hope to start a 14'r build someday soon. |
![]() | #69 |
thanks man, its kind of a shame that its now just a pile of parts... i had to rebuild my 2.2 blackjack for tomorrow's comp/GTG so the 14er had to give up its chassis and transmission. here pretty soon ill have a new blackjack chassis for the 14er to base off of.
![]() | #70 | |
| ![]() Quote:
![]() | #71 |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
All this time I thought the 14er's were referring to wheel base, now that i see that pic EP posted it looks like you're talking track width. Did I miss something?
![]() | #72 |
![]() | #73 |
Thats good to know, I'm planning on tearing into the TXT I bought last year and going the 14er route myself. Thanks for clearing that up.
![]() | #74 |
Quarry Creeper Join Date: Nov 2005 Location: Danville
![]() | #75 |
You might want to think about adding the RC4WD upper link mount brace.
![]() | #76 |
![]() | #77 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
great start deisel, glad the axles are working out for you.
![]() | #78 |
pics of the progress. its now being built on a k2-3s that i had laying around. i just love them reign products. making this motor fit into the transmission was some work! after about 30min of filing and sanding i got it to fit with a 16 tooth pinion. the clearance between the motor and the trans case is 17 ten thousandths of an inch. thats .0017" just over one and a half thousandths of an inch... this is the first time ive ever used a set of feeler gauges on an rc car. |
![]() | #79 |
I got the material to make my upper links. 5/32" solid steel rod sleeved with 8mm OD stainless steel tubing, capped off with revo ends. Ill be building them tonight.
![]() | #80 |
Rock Crawler Join Date: Sep 2005 Location: IDK
looks great! but i think the blackjack just looks better on it ![]() What bl motor is that? do you have some specs? Get on with it and finish the damn thing!! ![]() |
