11-04-2007, 10:11 PM | #1 |
Pebble Pounder Join Date: Jun 2004 Location: burton
| motors
What motors are you guys using for crawling without the help of the gd600 looking to switch to a 55t but what are some other options
11-04-2007, 10:45 PM | #2 |
| www.holmeshobbies.com brushless is the only way to go... you might try one of holmes cobalt puller motors too.
11-05-2007, 05:22 PM | #3 |
Pebble Pounder Join Date: Apr 2006 Location: Jackson
I put Novak brushless goat crawler in in mine with a gd-600 and it works great. I love it, way better than the 55t lathe motor. |
11-05-2007, 05:23 PM | #4 |
Most people use 55t motors, they are the best all around motor without getting expensive.
11-05-2007, 05:42 PM | #5 |
Two 35t in series worked pretty sweet. Small pinion gears, like 9 tooth, or 10. A single lathe motor is good, but just doesn't have the nads to be great. Try two Tamiya silver cans in series if ya got them laying around. |
11-05-2007, 05:43 PM | #6 |
Oh yeah, txt section duh. Two 55t motors in parallel with high voltage, 8t pinions. Or, one big outrunner. |
11-06-2007, 04:43 PM | #7 |
I ordered one integy 55t and hope it will do better than one 23t motor with the gd600. if it does not work out for the better than I will try a 5800 novak set up with the gd again any down sides on that
11-06-2007, 06:16 PM | #8 |
the novak high speed brushless setups ( 5300, 5700, 5800, etc...)dont have the control and features a crawler brushless system does. no drag brake, no 100% initial start up, etc...
11-07-2007, 07:46 AM | #9 |
| The high speed brushless systems do have drag brake and are water proof. The old one does not but I have both new and old super sports
02-19-2008, 05:02 PM | #10 |
Newbie Join Date: Dec 2007 Location: philippines
will a single 55t with stock pinions enough to power the txt? mild crawling only.
02-19-2008, 05:04 PM | #11 |
Barely, but sort of. Well, maybe with a 9 tooth pinion.
02-19-2008, 09:50 PM | #12 |
problem is I dont have enough run time only 15mins with a novak super duty and tamiya rz wired in parallel, 3300mah batts.
02-19-2008, 10:33 PM | #13 |
Wire them in series, you'll get a longer runtime.
02-20-2008, 01:36 AM | #14 |
Rock Stacker Join Date: Oct 2007 Location: Stevensville
I have two 45turn with 9tooth gears |
02-20-2008, 03:42 PM | #15 |
RCC Addict Join Date: Apr 2004 Location: 5280
I had twin Kyosho Mag Mayhems prior to the GD600.
02-20-2008, 07:18 PM | #16 |
Holmes Cobalt Puller 10T on 3cell Lipo or 8-10 Nihm cells, (no GD600) you will love it |
12-28-2008, 01:09 AM | #17 |
Newbie Join Date: Nov 2006 Location: perth W Australia
I run my TXT with stock diffs & tranny, 40 series moabs, novac rooster crawler ESC, integgy 45t lathe motor with 8t pinion & an intelect 4200 mAH, 7.2v NiMH battery. It scoots around the flats quite quickly but seems to stall under load while climbing. would twin 45's in series or paralel be better, or a single 55 or 60 stop it from stalling? thanks.
12-28-2008, 08:14 AM | #18 |
A gear reduction unit will cure the stall. |
12-29-2008, 06:28 PM | #19 |
thanks, GD 600 it is then !
