Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: nooby 2nd tuber attempt
Old 01-05-2008, 09:06 PM   #1
Default nooby 2nd tuber attempt
My first attempt was pretty goo but after messing with it for a couple months I figured it could be improved on, it had alot of torque twist and no adjustment in suspention. So after a wile this is what I came up with, now I have plenty of adjustment and I'm pretty happy with for now . Wheelbase is 15 3/4, 65t, R2 tranny, moab XL's, moped V16, JP's alum. knuckles up front, and rear is locked out. I do have plans to move batters to the knuckles I just need to find some cells. I'm also thinking of dropping to a 45t, I like wheel speed . Heres some pics, tell me what you think. Thanx.
http://s154.photobucket.com/albums/s.../rc%20crawler/
CrawlnYota33 is offline   Reply With Quote
Old 01-05-2008, 09:57 PM   #2
I like it, i love the stance of it. Good job
whitey07 is offline   Reply With Quote
Old 01-06-2008, 12:36 AM   #3
How do you like the R2 with the 65t....? How does it run?
5150bronco is offline   Reply With Quote
Old 01-06-2008, 01:31 PM   #4
Looks good man. What did you do to eliminate torque twist?
ToyotaTerrorist is offline   Reply With Quote
Old 01-06-2008, 02:32 PM   #5
The R2 seems to hold up pretty good so far, I'v been through one set of gears already but they were already stripped when I got the tranny. Only thing I don't like is it is super slow and I need wheel speed.
If you can see where my links are mounted the mounts have tons of adjustment I probly have 20 holes to move them around. I tried to keep my shocks as vertical as possible to, thats why I had to break down and buy the link mounts for the shocks. It seems to do pretty good so far.
Thnax for the input guys.
Old 01-12-2008, 06:58 PM   #6
Added some action pics, what ya think?
Old 01-13-2008, 12:22 PM   #7
Okay, thanks.
So, you stripped the gears in the tranny?
Are you thinkin of using a 55t lathe motor?
Are you thinkin of changing the pinion gear?
Let me know....., thanks, very helpful info!
Old 01-13-2008, 02:06 PM   #8
The gears were stripped when I got the tranny from a buddy but we turned the gears around and ran them for about 3 more months with no problems then they stripped again. I put a 35t on last night I'll let you know how that goes. Think I'm running an 8t on the pinion.
Old 01-14-2008, 10:20 PM   #9
wow, 35t and 8 pinion and it is too slow you said?
really?
tell me other applications you used...or combo's...
Old 01-15-2008, 06:50 PM   #10
really?
Before my TXT I had a TLT with a pede tranny and a stock TLT motor, it was too fast. The R2's are just geared to low for a 65t and 7 inch tall tires. IMO.
Old 01-16-2008, 08:39 PM   #11
okay. i see. well i am just starting with an r2 now. That is why i am asking.
I was thinkin of running 55t with 12 or 13 t pinion....
what do you think? what is your experience?
Old 01-17-2008, 05:16 AM   #12
For me a 75T Lathe on my R2 was to slow. But again, I personaly prefer lower gearing with gobs of torque.
Toph is offline   Reply With Quote
Old 01-17-2008, 07:48 PM   #13
Yea a 12 or 13t pinion would probly speed it up some. Theres really not a huge amount of diff between my 65t and the 35t, if I changed the pinion I would probly notice more.
Yea, it just comes down to what you like, just be carfull with that 75 and the R2!!
Old 01-18-2008, 10:56 PM   #14
so you think the change in wheel speed is mainly noticed only changing pinion then?
thanks.
Old 01-19-2008, 08:07 PM   #15
Well I take that back, I got some new batterys the other day and I help alot, there is a very noticible difference in wheel speed. I guess mine were just to old and week.
Old 01-20-2008, 01:33 PM   #16
okay, i see....it is good to run your battery dead completely every now and again then charge it to full capacity....
