| | #1 |
| Rock Crawler Join Date: Jan 2005 Location: Windsor, VA
| Here is mine. Has a rooster crawler ESC, Axiom 45 turn motor, Hitec 645MG Servo. Running stock rims and 1.9 mudslingers. I have a small body lift. Hope to add a LED kit and do some trimming to the front end for better approach angles and finish detaling the body with turn signals and what not. |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jan 2009 Location: Planet Earth
| That's a small body lift? Haha, jk |
| | #3 |
| R/C Investor ![]() Join Date: Apr 2008 Location: Wrightsville, PA
| Nice! What pinion did you use with the Axiom 45T? Is everything else in the trans stock? |
| | #4 |
| | #5 |
| | #6 |
| Yeah, I did the exact same thing. Cutting the fenders does make them look a little more realistic. Also, getting some 3" shocks and mounting them around all four corners will help too. The front A-arms take some grinding to swing far enough down. It increases ride hight, articulation, and makes the maximum shock compression longer, which also helps the rubbing issue. I am also tying to figure out how to modify the front end so I can put a uniform skid plate on it. If you figure that out, please let me know. Thanks |
| Thread Tools | |
| Display Modes | |
