07-23-2009, 03:08 PM | #61 |
That's the same CVDs that I got and the stubs are about 3-4mm wider than the stock setup.
07-24-2009, 10:41 PM | #62 |
Quarry Creeper Join Date: Jul 2009 Location: Bel Air, MD
could I get a better pic or two of the way yer rear shocks mount on the axle? thanks in advance! |
07-26-2009, 12:05 PM | #63 | |
Just remember that XC/CC-01 stuff is different than TA02 parts, especially the axles and knuckles. I didn't even compare the stock parts to the TA02 parts. It just went together without a problem. I didn't notice any effects of the rig being any wider, seems the same to me. | |
07-27-2009, 02:50 PM | #64 |
Okay... ran the 'Jero for a decent amount today, sand, rocks, mud and water. Many drops onto the front end and many times it was hopping. The Pajero was working great, then I noticed the right front wheel not turning. The actual CVD joint is fine, the shaft is slightly bent and I sheared the pins off the dogbone end at the differential output. Although you can't see it in the picture, but the shaft is bent and looks more like the pin just fell out. The hole appears to be slightly oval shaped but I should be able to get another pin into it. Even with the couple of issues I've had with these Yeah Racing CVDs, I'm still happy with them. Now that I think about it... Before I ran the Pajero this morning I actually preloaded that right front shock a bit more. Perhaps that was one reason why the shaft is bent, too much preload on the shocks not allowing the axles to ride where they should. |
07-29-2009, 09:53 PM | #65 |
So... I feel that it's time to test another type of axle in this neat-0 rig. I have a set of these on the way to test and I'll see if I can break them next. |
07-30-2009, 06:54 AM | #66 |
Where you find these at? ****EDIT**** NM found them http://www.asiatees.com/display.php?...del=TA02&pid=1 Last edited by constantmotion; 07-30-2009 at 07:18 AM. |
07-30-2009, 07:39 AM | #67 |
The stubs look long on the silvers ones vs. the blue ones. The silver ones look like the ones you currently have and the Yeah racing ones that I have. They don't have the step up on the spindle like the blue ones for the larger 6x12 bearing. Your new aluminum knuckles uses 2 5x11 bearing, right? Maybe that's why my shafts were too long..needed different knuckles, they were seating to deep in the knuckles. Found this list of different knuckles: TA01 Rear Knuckle (x2) 1150 bearings TA01 Front Knuckle (x2) 1150 bearings TA02 Rear Knuckle (x2) 1150 bearings TA02 Front Knuckle (x1) 1510 bearing (x1) 1260 bearing TA03 Rear Knuckle (x1) 1510 bearing (x1) 1260 bearing TA03 Front Knuckle (x1) 1510 bearing (x1) 1260 bearing CC01 FRONT=TA02 FRONT=TA03 FRONT |
07-30-2009, 08:36 AM | #68 | |
RCC Addict Join Date: Jun 2005 Location: St. Albans
07-30-2009, 09:12 AM | #69 |
07-30-2009, 09:25 AM | #70 | |
http://stores.shop.ebay.com/Sheldons...?_nkw=mip+ta03 Stick with the shiny ones... I seriously doubt that the aluminum bones would hold up to crawling. I never had any long term dependability from them racing off road. | |
07-30-2009, 11:06 AM | #71 |
The silver axles were not in stock hence the reason I didn't order those. Plus, if the blue units are wider, I'll run my wider front A-arms and hope they fit the width. Another thing..... who else with a CC-01 is ordering these things to test? I have some MIP CVDs that almost fit, just have to find the right bearings and correct length A-arms. |
07-30-2009, 12:30 PM | #72 | |
07-30-2009, 12:39 PM | #73 | |
Toyo....Those that you bought should work fine with the stock carriers. Last edited by constantmotion; 07-30-2009 at 12:43 PM. | |
07-30-2009, 01:48 PM | #74 | |
If not... oh well. I think this is actually fun! It's like 2003/2004 all over again when nothing was available for a crawler. I don't care for the plastic goods on the CC-01, I hope GPM can step up the plate and make some neat stuff. Another thing, I bought some dogbones that were labeled for the TA02W and they fit perfectly... not sure what was up with that. | |
07-30-2009, 01:49 PM | #75 | |
08-03-2009, 11:50 AM | #76 |
UPDATE!!! UPDATE!!! Got the GPM Racing TA02 Universals and holy crap... they are a direct replacement to the stock parts, no bearings needed or different knuckles required. They fit like they were made for the CC-01 setup. This is what I have.... Where I got them. Only took about 4 business days, not to shabby and on par with RCMart shipping times. http://www.asiatees.com/display.php?...del=TA02&pid=1 The angle doesn't seem to go as far and still work as smoothly as the CVDs but being a direct replacement is pretty cool. I think I'd rather have steel units but I'll have to do my punishment thing on the CC-01 again to see how well these units hold up. Headed out to the garage to swap the stock knuckles back over and take the rig out to play! |
08-03-2009, 12:01 PM | #77 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
cool, so what do these give you, more turning?
08-03-2009, 01:25 PM | #78 |
08-03-2009, 01:26 PM | #79 |
08-03-2009, 03:14 PM | #80 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
Did you already break the Yeah Racing ones?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/tamiya-xc-cc01/182040-toyofasts-cc-01-jero-goes.html | ||||
CC01= TA02 and TA03 Parts Compatability CONFIRMED - Page 3 - Scale 4x4 R/C Forums | This thread | Refback | 10-05-2011 10:00 AM |
