08-03-2009, 03:46 PM | #81 |
| Sort of.... I have bent one and lost a cross pin on the end of the shaft, one close to differential. Only issue so far. Okay... drove it, don't like it as much as the Yeah Racing CVDs. Looks like in order for these to help gain any sort of steering, I'll have to modify the stock plastic knuckles. The forward side and back side of the knuckle acts like a turn stop when trying to go to full left or full right. Too much material in the way. You notice how the TA02 Yeah Racing aluminum knuckles have the notches on the knuckles, that's what has to be done to the stock CC-01 units for these to help. I do like how nice they just drop in without any issues. I'll have to keep playing and try to break them. Being a GPM part and them now looking at making parts for the CC-01, if they were to make a new aluminum knuckle that has the front/back sides cut out to allow tighter steering..... that'd be the hot ticket to match up with these universal shafts. |
08-03-2009, 08:32 PM | #82 |
But you can get a little bit more steering with risking the dogbone popping out/bending....especially if you have already modded the steering knuckles to give ya a little bit more down travel.
08-03-2009, 08:53 PM | #83 |
| Yeah... So far no issues other than I need to modify the stock knuckles to allow for more steering. I have high hopes for these GPM universals. I plan to test them as much as I can this week after work.
08-06-2009, 12:27 PM | #84 |
RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
Great update! Nice work as usual. I'm glad to hear these results b/c I've just got mine up and running and experienced the dogbones popping out. I took some extra o rings and stuffed them up in the axles and works so far. I'll have to get some of these for sure.
08-30-2009, 07:46 PM | #85 |
Well... I took a few weeks off from driving any RC's and tonight I decided to charge up a 3 cell and run the Pajero around. Everything was going great until I blipped the throttle to get around a rock. As the Pajero made it around the edge of the rock, the left front tire went sky high and I hit the brakes..... that's the same moment when I saw a flash of blue hit the dirt and the left front tire spin like crazy. Those GPM aluminum universal shafts twisted and snapped. The joints seem to be okay, one of the pins started to work it's way out but push it back in and add a dab of CA it'll stay in place. Good thing I have a spare GPM shaft and a spare Yeah Racing CVD shaft. |
08-30-2009, 08:06 PM | #86 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
this thing is an axle breaking machine |
08-30-2009, 08:29 PM | #87 |
| Tell me about it! I don't think I ever broke this many TLT axles from back in the day. I need to get back into gear with this rig and try to make the IFS work correctly and stand up to MY abuse. So far I'm getting about 2-3 battery packs per axle breakage. |
08-30-2009, 10:12 PM | #88 |
Quarry Creeper Join Date: Feb 2008 Location: Clymer, NY
Damn dude, what kind of terrain do you run on? I have never broke a single part on either of mine. I know your huge ass tires are not helping matters any. I run Trail Docs on my Defender and it weighs in at just a few oz's under 8lbs and my other truck runs Outlanders. I whoop the piss outta them both and never have broke anything on either.
08-30-2009, 10:25 PM | #89 | |
I have broken front axles with the Flatirons, RC4wd Crushers, Trail Docs and even the stock TLT tires. Flatirons have no weight added, Trail Docs are the heavy SOBs with about 8oz for the fronts and 4oz for the rears, RC4WD tires have no weight and the stock TLT tires are just silly fat. I can't be the ONLY one out there having this many issues with front axles! | |
08-31-2009, 01:35 AM | #90 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
I think its unusual to say the least!
08-31-2009, 07:14 AM | #91 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
08-31-2009, 01:18 PM | #92 | |
| Maybe something is tweaked with my front end. It just seems odd that I keep breaking axles. Time to remove the 3mm lift to see if that will help ease up the breakage. That's really the only thing I can think of that is causing a possible issue..... Maybe I should just try to SAS this little rig and go pick up another CC-01 and start over.. Quote:
Any issues with loosing any cross pins? That's one issue I keep having with the Yeah Racing CVDs. Either a cross pin at the CVD joint or the pin on the "dogbone" side of the axle. I have CA holding them in now. | |
09-03-2009, 04:09 PM | #93 |
Newbie Join Date: May 2008 Location: Biloxi
Check this thread out for some axle/cvd compatability info http://www.scale4x4rc.org/forums/sho...hlight=cc01%3D I did all this research one day when I was bored. I think any FRONT TA02 or FRONT TA03 CVDS will work, if you can find them. Make sure they are for the front, NOT the rear I found these on ebay a while back, but I think they cost me $60 |
09-03-2009, 04:11 PM | #94 |
I bought those Tamiya CVD's for a Pajero I built, but I sold the Pajero before I ever converted over to CVD's. I got a new ReRelease CC01 Wrangler to build, I will put them in that and see how they hold up |
09-03-2009, 10:49 PM | #95 | |
My main goal is to widen the front suspension, longer a-arms, longer shocks and easier to find CVDs that will hold up to MY abuse. I already have som MIP CVDs that I want to use but it's finding some a-arms to work with them... or I have to make my own arms, which I'm starting to lean towards. | |
09-04-2009, 06:28 AM | #96 |
I have some kinda made in China aluminum TA03 knuckles that look similar to yours, but I think they are for the rear. The aluminum knuckles I have just have 1 hole in them for a turnbuckle vs the two holes that yours have. I am going to see if they fit, if they dont, I will trim down some stock plastic knuckles to get more steering throw. |
09-04-2009, 02:53 PM | #97 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
toyofast Your videos are some of the best in RCC , pleasure to watch |
09-04-2009, 03:39 PM | #98 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
09-04-2009, 08:16 PM | #99 | |
They are MIP, longer than the Yeah Racing but not by too much. Just need to increase the width of the stock arms by about 10-12mm longer or so. | |
09-10-2009, 08:12 PM | #100 |
Pebble Pounder Join Date: Sep 2009 Location: Melbourne, Australia
I'm a little bit confused.. For the CC01's what is better for the purposes used here the standard dogbone and stub axles or CVD's??
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/tamiya-xc-cc01/182040-toyofasts-cc-01-jero-goes.html | ||||
CC01= TA02 and TA03 Parts Compatability CONFIRMED - Page 3 - Scale 4x4 R/C Forums | This thread | Refback | 10-05-2011 10:00 AM |
