Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya XC/CC01
Thread: CC-01 Jeep
Old 07-01-2009, 03:41 PM   #1
IM A NEWBIEZZZ
PANDAbox's Avatar
Default CC-01 Jeep
Hey guys,
This will thread will be for the buildup of my Tamiya Jeep Wrangler.
Big thanks to:
Upgrade-rc
RCP crawlers
Chassis:
CC-01 Tub chassis
Suspension:
Modded rc4wd 80mm dual stage
or
Try and limit some scx10 shocks
Rims/Tires:
Proline 1.9 Titus/Titan black beadlocks
Proline 1.9 memory foams
Cut down Flat Irons
Body:
Wrangler body
Probably keep it white, like everything else.
Drivetrain:
MIP center cvd
Aluminium hexes
Front Axle:
Locked front diff
Aluminum hexes
Rear Axle:
Locked rear diff
Aluminum hexes
Electronics:
LRP brushless crawler esc
LRP brushless crawler motor
Airtronics 94162z servo
Aitronics crawler radio
Airtronics 8ch 2.4ghz receiver
Reedy 35c 5000mah 7.4v lipo
Black 12awg wire
Onto the beginning pics
Oh boy, here we go
Body will have cut and trimmed fender wells. I will also be taking off the front bumper.
Top side of the chassis
Underside of the chassis
Gears all set and ready
Front suspension ready to go
PANDAbox is offline   Reply With Quote
Old 07-01-2009, 05:08 PM   #2
Your gears need some grease...
4u2nv is offline   Reply With Quote
Old 07-01-2009, 06:31 PM   #3
and you really should add bearings or the gear box will be loud...
fathead is offline   Reply With Quote
Old 07-02-2009, 09:02 AM   #4
On the lookout for Rocks
constantmotion's Avatar
Can you run some flanged or normal bearings in place of the plastic shaft bushing thingys?
constantmotion is offline   Reply With Quote
Old 07-02-2009, 10:13 AM   #5
Originally Posted by constantmotion View Post
Can you run some flanged bearings in place of the plastic shaft bushing thingys?
not sure about the flanged bearings, but ball bearings are available for inside your spur gear and drive gear assemblies as well as the rest of the vehicle. like what was mentioned before, highly recommended.
pardonmyn00b is online now   Reply With Quote
Old 07-02-2009, 01:24 PM   #6
IM A NEWBIEZZZ
PANDAbox's Avatar
Grease was added after the pics were taken .
Ball bearing kit is on order. I will throw this in once they arrive.
