Would you mind show us how you fixed the problem, pictures would help a lot, thanks. |
Even I put the GPM kit on a brand new chassis, and brand new traxxas 2075 servo, it still has a little movement in the steering. |
I went to the GPM website and found that I couldnt buy direct, unless I contact them first. Is this correct? EDIT: I reread the thread and understand that I need to contact them directly. Thanks. |
Today I finally got around to installing the GPM Steering kit in my Hummer Hx CC01. I got it together with the included phillips-head screws and tightened it as much as I could without stripping the screw heads. Afterwards I couldn't get the truck trimmed straight and it wouldn't hold a straight line for anything. Then while tinkering with the steering settings on my radio, I clipped the pipe along the side of the track and lost almost all steering. I picked it up and went back to the pits to discover that the screw in the bottom of the long through-rod had backed off. I thought this was rather strange considering the amount of force I used when assembling it the first time. I replaced that screw with a 3x12mm cap head and used my 2.5mm hex driver to really tighten it down. I was able to put much more force into it with the hex driver than I could ever think of with the phillips screwdriver. After putting the front of the truck back together, I found that almost all excess slop was now gone, the truck tracks straight now and I have increased usable steering throw so that the truck can circle in 6-8 feet of space. Not bad for front and rear locked diffs. The kit is definately worth the $13 price, but do yourself a favor and pick up the extra hex screws to replace the phillips head hardware. At the very least get the 3x12mm hex screw for the bottom of the through rod so you can get it tight enough."thumbsup" |
Thank you guys for the tricks. "thumbsup" |
thread locker, tighten it up. It still show some slop. |
Did you check to see if the keyed part at the bottom was rounded off? |
any one try the new gear set yet from gpm. wonder if that will fix my gears form slipping? |
Re: CC-01/XC owners.... Please read. word on this thread! |
Re: CC-01/XC owners.... Please read. I decided to race my minicooper drifter vs a vaterra kemora and noticed that the rear shocks are almost the same exact size as my drifter which happens to be the same size as the socks on the cc01 and the springs come in 3 sets soft med hard and the stocks being adjustable and able to hold oil. also the front shocks for the kemora are just slightly smaller which would be good for people who want the springs to be a 50/50 droop with a cc01. |
