06-22-2009, 07:56 PM | #1 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
| rc channel cc01 shocks
Has anyone tried the rc channel shocks that are made to be used with their aluminum upgrades? http://www.shop.rpphobby.com/product...productId=1321 They would give a little more lift with the proper front end modifications. Only thing i dont know is how soft/hard they are. |
06-23-2009, 10:42 PM | #2 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
Sorry, haven't heard of these before. Write the website, tell them what your going to do and want to know if they are soft springs..maybe they can send you some specs on it. RCPlanet did for me on some shocks I was looking at.
06-24-2009, 09:59 AM | #3 |
Quarry Creeper Join Date: Aug 2007 Location: Temple
im using HR losi mini shocks on my blazer project, heres some pics |
06-24-2009, 11:55 AM | #4 |
Quarry Creeper Join Date: Dec 2005 Location: Orrington
i like those hr shocks. they look pretty scale. how are they working for you?
06-24-2009, 12:02 PM | #5 |
they work great actually, you can adjust them to you liking, when you order them, you also get a set of silver/chrome springs along with the blue ones
06-24-2009, 02:34 PM | #6 |
those HR shocks look pretty nice. what is the length?
06-25-2009, 10:45 AM | #7 |
Quarry Creeper Join Date: Jan 2008 Location: san jose
those losis look great! I perosnally use the RC4wd dual spring 80mm shox. They do bind when you have the o rings in them but I figured out the problem. It was the piston rods that were binding. If you sand them down then polish them they wont bind as much because those rods were machined and if u run your finger nail down them u can feel the little grooves. |
08-27-2009, 09:29 PM | #8 |
Newbie Join Date: Apr 2009 Location: Melbourne, Australia
Hi guys! Sorry to drag up an old thread but I thought it was worth mentioning my experience with RC channel shocks. I got the metal axle kit and the aluminium shocks earlier in the week - the metal axle kit is fantastic, the extra travel you gain in the front end alone makes it worth it, although you lose about 5mm of ground clearance as the lower skid plate is spaced downwards. However, the aluminium shocks are terrible. The seal at the base of the shock body (where the piston slides) is some sort of rubber, but it has way too much friction, the piston rod resists travel in a major way. I put thin oil in them, the shock won't decompress under it's own power, and with the shock mounted on the car, if you push the chassis downwards it will not lift up again as you would expect, it takes about 2 minutes for the shock to decompress. Absolutely terrible. It is a pity, because they are a nice looking shock, but whatever the seal is is just no good. And it's not possible to fit o-rings in there as an alternative, the lower seal is held in by a tiny spring clip, not a threaded cap like every other shock I have. I may try enlarging the hole slightly, but my concern is that that will just lead to oil leaking out of the shock, not a great solution. I refitted the standard CC-01 shocks and it works fine. Now I am just waiting on some RC4WD 80mm scale shocks, hopefully those are good! |
09-04-2009, 08:54 AM | #9 |
Rock Crawler Join Date: Jul 2008 Location: River Falls
