![]() | #1 |
Quarry Creeper Join Date: Jul 2009 Location: Bel Air, MD
Well after quite a few weeks of waiting for parts, getting the wrong ones, buying mislabled parts etc... I finally got under way last night. I decided the front end definitly needed to be bobbed as yes,that brickwall front was a pain and an approach angle killer. So as you can see, a slight modification was made to the chassis. ![]() Then I decided with a longer wheelbase, I definitly needed a longer driveshaft and I'm just not a fan of the glued together Traxxas shafts. I'm sure they work fine, but, I like a more "finished looked". Don't mind me, it's just my OCD. SO I took a drive-shaft set from a Maxx truck from teh diff to teh wheels, and used THAT instead. The stubshaft coming out of a Maxx trans is larger in siges so I needed to make a sleeve to "grow" the shaft size to fit it into the Traxxas knuckle. Inside the knuckle has 2 flat spots since Traxxas has 2 flat sides on their shafts. Tamiya has only 1 so I took a small dremel ball tip ( drillbit works too kinda) and removed it so there was only 1 flat spot. I slid the sleeve over the Tamiya shaft, used a pair of pliars to flatten the tub on the flat spot, and slipped it in the Traxxas knuckle. You also have ot pick up (4) 4mm set screws as I opnted to not use the Traxxas units. I wanted a set screw on each side,no one long one. Slide it on the shaft, adjest if to make it straight if you need to and cinch the setscrews in. Now you have a seriously heavyduty driveshaft! ![]() ![]() The rear suspension needed soem attention too as the way I made new link mounts etc didn't let the shocks mount properly and I wasn't looking to use bicycle chain halflinks as extentions. I ended up using TLT-1 brackets and modifying the lower links extensivly with a Dremel ![]() ![]() Next I fitted up some of the LandRover wheels and tires from my brother stash and test fit them, way better than the stock size BFG's but I might use the black Hummer wheels I have though,not sure. Next I finally got a body from Crunky and had to figure a way to mount it without the typcial holes in the hood or sides....so I fabbed up a mount system using the stock mounts on the body and a few pieces of aluminum angle and some old RC10L body posts. With that done, now I just needed to do do the back,I cheated and put 2 extremely short posts through the bed floor where I can easily hide it with a spare tire, coolers etc..... ![]() ![]() ![]() ![]() I'm not too convinced yet this is the body thats staying and yes I know I need to trim the wheel openings some etc. This WILL do for now however but I think I am going ot keep looking for a Jeep SUV body or a LandRover Discovery etc.... During all this time.... the ENTIRE truck has been gone over and reworked as well. When I bought it it was a basketcase. The bearings have been cleaned and oiled with Royal Purple, a new gear set was ordered and installed since the PO looks like he was too cheap for bearings for a while and they were badly worn. The diffs were filled wth OFNA 120,000 weight silicone after assembling them with allthe standard gears. It's been a month and it hasn't leaked out at ALL. So all the naysayers... you may be right in a few MORE months,but its GREAT now. Its a limited slip unit basically. It WILL let a wheel spin alone and still turn in a tighter radius but it won't free spin at high RPM because of how thick the fluid is. More to come as I get to it.... |
![]() | #2 |
Newbie Join Date: Jan 2009 Location: Istanbul
well done, small but effective mods. Gives me ideas for my Pajero. How did you mount TLT brackets to axle case? I saw cycle chain mounted also but couldn't figure out the way they're mounted. Do you screw them to axle case? Is there enough clearence to axle shaft? Asil |
![]() | #3 |
Pebble Pounder Join Date: Mar 2009 Location: Grants Pass, OR
Yeah trim those fenders and mount it a little lower to hide more of the chassis and that thing will be pretty sweet. Nice body mounts.
![]() | #4 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
Looking good sofar. Keep up the hard work. Let us know how things come along. ![]() |
![]() | #5 |
Well, so far I cant drop the body any lower in the back,without raising the floor of the bed,which I was trying to avoid....as for the rear mounts, I used the original hole for teh arm mounts and drilled a small hole in the axle tube on each side and used a short 3x8 selftapper in it for the center hole.... the bottom mount is the same as the top, only its been trimmed and ground down some with a dremel for better clearance..
![]() | #6 | |
| ![]() Quote:
Asil | |
![]() | #7 |
Quarry Creeper Join Date: Feb 2008 Location: Clymer, NY
Lookin great so far bro, I have one suggestion that will help with the links that will hang up the way they are now mounted. Just drill a hole in the side of the molded in frame rails and use a 3mm bolt, lock nut and washer on each side. Trust me, it will glide over everything, where the way you have it now, they link ends and screw head will catch on everything. ![]() ![]() |
![]() | #8 |
Well, Once I get a body on there I really like.. I'm gonna mess with shock legnths as they bottom out before the tires rub the chassis and I am losing almost 3/4" travel because of it..... I am 99% sure I am going to sell the Chevy HD body I just got and use a new Nissan Pickup body..... Team Blue Groove on Ebay is doing Lexan re-productions of them and mine will be here in a few days.... I figure the suspension is a nice match to the real truck, so why not? ![]() |
![]() | #9 |
Do you have a pic of the Nissan body? Is it a Frontier or Hardbody? I would love to find a D40 platform Frontier body to match my 1:1 truck.
![]() | #10 |
I'm HOPING these links will work....It's a D21 Hardbody 86.5 to 93 I think was the bodystyle, not sure,might have been till 96. |
![]() | #11 |
Well, after a few days of the body ebing here and not having time to touch it, its painted and on, just no lighting in it yet, still working on that, bear with me... I think I am going ot mount the light units to the chassis ,rather than the body so the body is easier to get off with less wiring crap.... The body is a Team Blue Groove Reproduction of the famous Tamiya Nissan King Cab. The detail isnt perfect or super definied so its hard to hit your body lines for lights etc when cutting the masking unless you trace them in Sharpie on the otherside first. This IS good however as you have some leeway to be as detailed or undetailed as you want. Bear in mind there is NO overspray mask so tape the outside up accordingly! I'll keep ya updated! Love this body [IMG] ![]() [IMG] ![]() |
![]() | #12 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
looks very cool! Love that body too!
![]() | #13 |
Well, the MRC speedcontrol is in and rewird and runs great! Its not a HUGE improvement over the stock Tamiya ESC but the dragbrake IS nice ![]() ![]() ![]() |
![]() | #14 |
Rock Stacker Join Date: Oct 2008 Location: Keene NH
You keep your wires very tidy, it makes me look like a slob
