10-09-2009, 03:05 AM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Twentynine Palms
| CC01/XC Hummer H3 build Update 9/10/10
Started this build on rc4wd a few days ago, but figured I'd share! It's my first build and, to be honest, I'm quite proud of it. Lol. Lots of pictures below! Maya Group 1:10 Hummer H3, out of the box. A nice rear-end! Beautiful included interior! Starting off. Temporary links until I can get some better hardware in. EMaxx steering links. First body mock-up. Body mounted. I decided to use the tried and true posts/pins method because I'm using a Traxxas XL5 ESC, and I need to take the body off of the truck to turn the ESC on/off. A decent amount of flex, even with the temporary links. The bright, included soft-blue LEDs. Interior mounting. Driveshafts and pilot bearing. Still a lot to do! I want to do more detailing on the body, mostly in the form of highlighting panel lines with a panel line pen. The front diff is locked. Tires/wheels are going to be HPI black 10-spokes with RC4WD Dirt Grabbers. New links need to be made and all of the linkages on the steering will be rebuilt and tightened up. Still waiting for either RC4WD or GPM to get their alloy steering kits out. Also going to pick up a set of the 80mm internal spring scale shocks from RC4WD with red boots. Lots to do! Current running gear: Fifty Five motor XL-5 ESC Associated high-torque servo 3600MAh Wolfpack 6c battery Airtronics MX-3 radio 'Real strong runner. Just needs better shoes! Last edited by rampage; 09-10-2010 at 11:49 AM. |
10-09-2009, 05:32 AM | #2 |
Newbie Join Date: Aug 2008 Location: Gonzales
Good start on your H3. Where did you get that body from? I'm looking to build a copy of my 1:1.
10-09-2009, 07:57 AM | #3 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
I like it! Seems to fit the CC just nicely. I also like how you used the interior. |
10-09-2009, 11:24 AM | #4 |
Ooh, a 1:1 owner. That's great! The body, you can get from Target or Amazon. Just search "Maya H3" and pick up the 1:10th scale one. They also have one in 1:18th. It's only $49.00, which is a great price for what you get, I think! I'm thinking about a 1:1 as well. But I'll likely wait a few years until I can get an Alpha at a nice, pre-owned price. |
10-09-2009, 06:42 PM | #5 |
Quarry Creeper Join Date: Jun 2009 Location: SoCal
Great start. Love the body. Found one here for $48.xx http://www.bizrate.com/robotic_radio...572863565.html |
10-09-2009, 06:51 PM | #6 |
That's the one! Apparently it comes in either red or yellow. It really is a great body. Very detailed, and nice and thick. Weighs a ton, too. I'm going to have to beef up the springs, because, like her 1:1 sister's, she's a heafty girl. |
10-09-2009, 08:28 PM | #7 | |
10-09-2009, 08:32 PM | #8 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
looks cool man, nice pillot bearing on that drive shaft |
10-10-2009, 12:01 AM | #9 |
Pebble Pounder Join Date: Mar 2009 Location: Orange, CA
Very nice! I will definitely be following your build. I would love to build a white one with black rims just like my 1:1. |
10-10-2009, 02:49 AM | #10 | |
Thanks for the comments! Especially from the 1:1 owners. It's cool to get your input, since I'm trying to make this build as near-scale as possible, including things like rideheight and the likes. I think I've got it pretty good so far! We'll see how it sits with the Dirt Grabbers when I get them. Not much work tonight, unfortunately. Got tired pretty early and don't really have a lot to do until I place my orders, probably around payday. But I did work on the steering a bit. I noticed that after I locked the front diff, the steering was virtually nullified. Studying the C-hubs a bit, there were two small flanges and a pin the back of each C-hub that prevented the knuckles from moving quite a bit..So I removed them. Got lots of steering now. Steers better then it did with the front diff open and the rear diff locked. Quote:
10-10-2009, 02:59 AM | #11 |
Newbie Join Date: Oct 2009 Location: Moab
nice build i like the color
10-10-2009, 06:18 PM | #12 |
Well, I don't really have much else to do until I can get the rest of the stuff I need--wheels, tires, things of that sort, so I went ahead with some of the misc. details. Like this. Scale skidplate. I think it looks great on there. I'm going to paint it aluminum, so it more matches some of the 1:1s. Last edited by rampage; 10-10-2009 at 11:08 PM. |
10-11-2009, 11:38 PM | #13 |
Wow, that skid plate looks great! Just like my 1:1. I have a ton of pics of my 1:1 off-roading, let me know if you need any. |
10-12-2009, 12:54 AM | #14 |
RCC Addict Join Date: Oct 2007 Location: Long Island-Land of one batch of rocks in Sag Harbor and at least one fellow crawler
Nice work, I love the skid!
10-12-2009, 03:28 AM | #15 |
Thanks! I really appreciate the comments! I like the front skid too. I may try to "bring it up" a bit tho so that the lip meets the bumper. I know it's a flowing component on the 1:1, and I like that look. Update! I said before I wanted to do a roof rack to help hide the rear body posts, and I went ahead and did it! I went rummaging thru some of my old parts and found a nice rack, got it modded and bolted on the truck. In the excitement, I kind of screwed up and drilled one of the holes in the wrong place..So I just moved one of the OEM cross racks back a bit. It sits a bit crooked, but I won't tell if you won't, right? :sht: Anyway, the rack is on, looks great I think and does what it's supposed to do..draws attention away from the body posts. Since I'm going to be keeping the links I have on there at least until I can build new ones around payday, I went ahead and adjusted them properly and got the shocks 'mounted'. Short slips of fuel tubing over the link. Shocks don't budge. I also stiffened the rear springs. Associated 3.20 lb RC10B2/B3 front springs. Work great! Gives me the height I want with no sag while staying super-flexible and "springy". Last edited by rampage; 10-12-2009 at 03:38 AM. |
10-13-2009, 12:10 AM | #16 |
Just a little update tonight. I went ahead and added some steps. I think they look good on there! Add a bit of character to the body. I'm still just trying to occupy myself until I get the rest of my stuff. |
10-13-2009, 01:07 AM | #17 |
In my brief runs of the truck, I was sort of worried about my radio range. Got lots of twitching over just a few feet with the TX's antenna down, and it's an FM radio, so yeah. I want to keep the antenna hidden, so I have come up with a solution. It'll be painted black before I'm done, but I thought it came out really neat-looking. Functional, too! I'm going to route the antenna from the RX to the scale antenna, and with any sort of luck, my radio issues will end. |
10-13-2009, 12:50 PM | #18 |
| I think these are the closest to the split 7-spoke wheels I'm ever going to find, so I'll be using these when they're available. I'll strip the chome off and paint them, probably black. |
10-13-2009, 03:04 PM | #19 |
Those are pretty cool, and they are probably the closest 12mm hex wheel to the originals, but can you use the originals? It seems you might be able to modify them to work with the CC wheels... What size were the ones that came with the body? |
10-13-2009, 03:10 PM | #20 |
I thought about trying to use the originals, but they're an odd size. They're like 2.1" or so, not 1.9 and not 2.2..They're just a really odd size. They look too big for the truck, and that's the thing that really kept me from trying to use them. They just look too big. The HPI wheels are 29mm width, instead of the standard touring car 26mm, but I don't think that'll make a huge difference with the Dirt Grabber wheels. Also the minimum 3mm offset worries me a bit, but if push comes to shove I ca use skinnier hexes. |
