12-22-2009, 09:14 PM | #41 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
| Romulus...........the zip tie is lost, staired at my junk till I came up with the new strap system. Also made the tamiya hilift jack look better and then weathered the carrier and jack.
12-23-2009, 04:51 PM | #42 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
looks much better |
12-23-2009, 09:16 PM | #43 |
12-24-2009, 04:48 PM | #44 |
i hope you dont think i'm trying to tell you how to build your truck. i was just saying it looks much better
12-24-2009, 05:39 PM | #45 |
Pebble Pounder Join Date: Sep 2009 Location: Melbourne, Australia
How'd you make that thing? Just heat up some real thing styrene over the foam block? Looks good by the way |
12-24-2009, 09:32 PM | #46 |
12-24-2009, 09:36 PM | #47 | |
Oh yeah, wear some thick gloves like welding gloves cause you will need to hang onto the assembly while you heat it. | |
12-26-2009, 01:24 AM | #48 |
Rock Stacker Join Date: Feb 2009 Location: Waukesha, WI
I want that rack! I have to make one sometime "First attempt" Nice Jeep build btw! -Tom |
12-26-2009, 03:38 PM | #49 |
Pebble Pounder Join Date: Nov 2009 Location: Monterey Bay, CA
where did you get the aluminum drive shaft?
12-26-2009, 03:58 PM | #50 |
12-26-2009, 04:03 PM | #51 |
12-26-2009, 08:45 PM | #52 | |
Give it a go, this rack was the first time I welded somthing this small.........and the first time I welded a rack instead of brazing. A little update while I am here.............made a cooler for the rack. | |
12-26-2009, 09:08 PM | #53 |
Thats cool, Yea I'm gonna go the Brazing route (I have a welder) but seems a bit much for a job like this. I just need to get some stuff for brazing, Tourch, 45% silver rods ect.. Cooler looks good too. |
12-26-2009, 11:52 PM | #54 | |
Thanks I kinda like the welder for rod, you can work faster and you don't have to worry about heating the last joint you did if it is close to the one you are working on. When you braze you always run the risk of releasing other spots if the heat is to much. My 2 cents. | |
12-27-2009, 12:27 AM | #55 |
That is true, give it one quick tac and be done. Just seems kinda scary to sit in the basement at a table with a Arc welder by your side (lol) I have a Lincoln Weld-Pak 100 btw.. |
12-27-2009, 03:31 PM | #56 | |
Yah, I understand your fear, I have a shop that is not attached to the house so I don't think about those things to much.............I use a Lincoln weld-pack 155. Little update on the cooler................needed a strap so it would not go flying. The buckle works too. | |
12-27-2009, 05:34 PM | #57 |
Nice strap. We have a garage and a heater (So I don't do much in there during winter time unless I have to do something to the car) I like how the rack support wraps around the body, looks like the real thing |
12-28-2009, 09:01 PM | #58 |
12-30-2009, 10:29 PM | #59 |
I felt that I needed a shovel just in case I got stuck, this should look nice mounted to the side of the rack.
12-31-2009, 02:44 AM | #60 |
Newbie Join Date: Dec 2009 Location: Sweden
way cool jeep.. Where did you get the extra lights? I realy liked the CB wip also |
