Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: New toy. XC FJ.
Old 08-14-2010, 01:40 PM   #41
Hey Scale, can you show me how you did your drive line....
very cool rig man, I had the same body roll with my S10, I picked some adjustable shocks, just had to play with them (adjusting the shock collar) took a while, but got "rid" of some of it...I know you know this, but just wanted to share with the others that were asking about it.
I was going to do the same to the steering, but if I want to run the CC01 in a CC01 class, they state that the servo must be in the stock location...sucks
squatch71 is offline   Reply With Quote
Old 08-14-2010, 03:57 PM   #42
Funny guy....
Ive messed with these shocks 10 times, i need to throw them away.
I love rc4wd products, but their shocks are JUNK. Im only using them because #1 they came on the truck, #2 im a broke mofo
ScalerLover is offline   Reply With Quote
Old 08-24-2010, 05:33 PM   #43
Originally Posted by ScalerLover View Post
Exactly.
The rod is 8-32.
Rod ends are revo, or jato.
Servo mount is as easy as cutting a slot in each side of the tub for the servo ears to sit in, then adding a cross brace to pull the tub together sightly and lock the servo into place.
The cross brace is simple, i used two body posts screwed together, then cut to length and a screw ran into each end through the tub.
hi,
im just wondering if where can i get the 8-32 rod???
sid15 is offline   Reply With Quote
Old 08-24-2010, 06:37 PM   #44
Originally Posted by sid15 View Post
hi,
Any home maintenance store, IE: Lowes, Home Depo, Menards, True Value etc etc.
Old 08-26-2010, 12:27 AM   #45
Figured if i was gonna actually keep running this thing i might as well try to make it turn better.
So i stole one of Stus tricks so i can has ackerman too
hi,
did you do this extension for the steering arms???
Old 08-26-2010, 11:30 AM   #46
hi,
Yes.
Old 08-27-2010, 12:37 AM   #47
Yes.
how the steering in your kit now???
Old 08-27-2010, 09:13 AM   #48
Better then it was before ?
