02-10-2010, 02:43 AM | #1 |
Rock Stacker Join Date: Jul 2008 Location: huntsville
| cc 01 help
hi i just finished building my cc01 kit and it seems that i have a big issue with it.... when i press the throttle forward it will move a bit and started to like lock gears tires idont know how to call it... and it seems that my front tire is set toe out.... and if i installed the steering kit correctly.. i dont know to post pics here...sorry... thanks |
02-10-2010, 07:22 AM | #2 |
Rock Stacker Join Date: Jul 2009 Location: Philippines
Sid, You might have used a long screw for the right (when looking at it upside down) steering arm. Somehow it interferes with the gears. That happened to me too. Just replace the screw with a shorter one instead. Here's a pix i got from GPM recently. Might help. As for the toe out, you can probably adjust the steering links by making them longer to make the wheels move inwards (toe in). |
02-10-2010, 11:10 AM | #3 | |
02-10-2010, 11:30 AM | #4 |
Quarry Creeper Join Date: Jan 2008 Location: san jose
does it grind when you take the motor out?
02-10-2010, 11:57 AM | #5 |
02-10-2010, 12:27 PM | #6 | |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
This will teach you how to upload pics Posting Pics For Dummies | |
02-10-2010, 10:50 PM | #7 |
Hi Sid, If you didnt use a long screw, then the problem may not be in your steering system. Did you lock either one of the rear or front differentials when you were assembleng the gears? |
02-10-2010, 11:52 PM | #8 |
| yup i lock both the front and the back gears... still having the same problem....what should i do...
02-11-2010, 01:02 AM | #9 |
Sid, I think you've got to post pictures so we can see what might be wrong. Just open a photobucket account, upload your pictures there. When they've been uploded, each picture will have a URL address like "http/...., or something like that, that you can higlight, then copy, then paste to this thread or any thread when you reply or make a new thread. Hope you get to do that. Another suggestion would be to maybe open up your gearboxes again and double check. |
02-11-2010, 02:13 AM | #10 | |
hope i can get this fixed it's very frustrating..... thanks mix http://s888.photobucket.com/albums/ac90/evo4_jet/ | |
02-11-2010, 02:18 AM | #11 |
Pebble Pounder Join Date: Sep 2009 Location: Melbourne, Australia
omfg Mix where did you get that front gearbox brace??? I WANT ONE! Sid you need to show us the underside of your truck with the skid plate/base plate off and a pic of the gearbox with the top cover off so we can try and diagnose your issue. Last edited by Junkz0r; 02-11-2010 at 02:22 AM. |
02-11-2010, 05:12 AM | #12 |
Quarry Creeper Join Date: Sep 2007 Location: New Zealand
Might be a silly idea but are your dog bones in the front seated properly and they havent jumped out on one side hence your toe out problem ?
02-11-2010, 10:41 AM | #13 | |
http://s888.photobucket.com/albums/ac90/evo4_jet/ and by the way i did follow blackfoots thread on how to lock the differentials... Last edited by sid15; 02-11-2010 at 10:57 AM. | |
02-11-2010, 08:51 PM | #14 | |
Hi Junkz0r, Its from GPM, and I think its available from them already, that picture is not my rig by the way, its a pix that GPM sent me. | |
02-11-2010, 09:01 PM | #15 | |
I saw your pictures already, from the looks of it, I dont see anything wrong with your front gears. What I did notice was that your main steering arm underneath looks quite loose cause both arms look like they are not that even. But that really wouldnt cause your rig to not move. You can also angle your servo saver a bit closer to midpoint so that you can have more steering adjustment. I'll send you a PM. Mix | |
02-11-2010, 11:13 PM | #16 | |
can you post again your rig?? i just want to chck if how did you set the steering and the angle oy your servo... please and thanks.. | |
02-12-2010, 04:28 PM | #17 |
Newbie Join Date: Sep 2009 Location: EU
02-13-2010, 06:53 AM | #18 |
02-13-2010, 11:04 PM | #19 |
02-14-2010, 01:17 AM | #20 |
Check hex for wheels ... part No. C1 and C3. C1 are front, C3 are rear. They are different. When change it, one or two wheels are locked by its M4 flange nut. I don't understand to your problem exactly. Post short video of this cause. Thank's. |
