03-28-2010, 06:27 PM | #1 |
Newbie Join Date: Feb 2010 Location: roseville
| ?*?cc-01 diff question???
whats the easiest way to lock the tamiya cc-01 front diff? I cant stand open diff in the front. |
03-28-2010, 08:50 PM | #2 |
Newbie Join Date: May 2007 Location: R Ken Saw
fill it with hot glue or jb weld... i cant remember if you can move one of spider gears to lock it or not... i added thin washers behind a couple of the spider gears, this almost locked the diff but when it gets into a bind the other tire will unload |
03-28-2010, 09:39 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
Take an extra spider gear and drop it in between two of the ones on the "Y" shaft in the diff.
03-29-2010, 10:36 AM | #4 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
| Search and you will find your answers. The easiest way is to take one of the spider gears out and drop it in between the other two. This will lock it and if you even want it open again just put the gear back.
03-29-2010, 08:35 PM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
Like so |
03-30-2010, 05:33 AM | #6 |
Newbie Join Date: Sep 2009 Location: EU
It is simpler to close diff's cover. |
04-01-2010, 09:15 AM | #7 |
3 Spider gears are sufficient enough.
04-02-2010, 08:46 PM | #8 |
Quarry Creeper Join Date: Oct 2009 Location: Twentynine Palms
Go for a limited-slip front diff. It's tight enough to be effective, but you don't loose steering. |
