Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: my new cc01 land cruiser!
Old 02-06-2010, 12:48 AM   #1
Default my new cc01 land cruiser!
hi there guys just got my tamiya cc01 land cruiser and been reading some of the thread here in rccrawler forum. Just wondering if you can help me with some useful guides on mods and performance of the kit?? Thanks in advance!
sid15 is offline   Reply With Quote
Old 02-06-2010, 08:09 AM   #2
Hey sid15, great to hear that you've got your CC01 already! Actually, there's a whole lot you can do to mod the CC01, but the most basic, I guess, would be to lock both diffs and get better tires. You've got the steering problem covered since your gpm kit is on the way. A high torque servo like hitec will also give you better steering performance. Ball bearings would also work great.
Suspension lifts, changing the rear links, changing shocks, there is really so so much more you can do, but the ones i initially mentioned would basically make your rig run better on the trails. Just keep checking out the rigs and mods here and you'll get so many ideas.
Have fun with your CC01!
mix237 is offline   Reply With Quote
Old 02-06-2010, 09:19 AM   #3
Post up some pictures! These CC-01's are good out of the box not much to do to them other than buy the GPM steering kit.
Grumpster1980 is offline   Reply With Quote
Old 02-06-2010, 10:40 AM   #4
Default re
tnx mix. yup surely i will post some pictures of my kit! can't wait to run it outside!
Old 02-06-2010, 06:10 PM   #5
Looking forward to seeing the pics. I've recently built one. I'm starting to try a few simple mods......
These are before any mods:
http://www.nehp.net/~jimw/crawler/crawlers%20026.jpg
http://www.nehp.net/~jimw/crawler/crawlers%20027.jpg
http://www.nehp.net/~jimw/crawler/crawlers%20028.jpg
I'll post more pics after some mods.
Jim
jim_w is offline   Reply With Quote
Old 02-07-2010, 01:22 AM   #6
is it a must to have ball bearing on cc 01??? because i didn't order any yet.... just wanna ask before i assemble my kit... thanks..
Old 02-07-2010, 01:05 PM   #7
More pics after a few mods this morning. New tires, rear suspension mod from "BLACKFOOT", front bearings, and locked the front diff.
http://www.nehp.net/~jimw/toyota/
...work in progress.....
Jim
Old 02-07-2010, 01:22 PM   #8
Is the new FJ40 CC-01's body mounted like that with the posts through the body? I kind of liked the way the old ones were mounted.
FuriousCal is offline   Reply With Quote
Old 02-07-2010, 02:07 PM   #9
Yes, the lexan shell, CC-01 bodys mount just like any other lexan shell. With a little modification it would not be hard to fab up some new mounts with something like velcro though.
fixed13 is offline   Reply With Quote
Old 02-08-2010, 07:52 AM   #10
Oh dang, I didn't know the new CC01's had lexan bodies. Why the heck are they so much more expensive?!?
Old 02-08-2010, 08:44 AM   #11
you can mount the body without post holes, if you use velcro or rare earth magnets, dont know about the price, but these bodys look great with a bit of tlc
mine is mounted with velcro at front and back, and some internal bodymounts I made from styrene on the inner sides.
that is mine, though its a custom chassis not cc01
Positronic is offline   Reply With Quote
Old 02-08-2010, 10:08 PM   #12
Makes a world of difference. TCS sells them cheap!!
Old 02-09-2010, 09:45 PM   #13
TCS??? my location is in canada..do you know their website??? tnx
Old 02-09-2010, 10:34 PM   #14
http://www.tcscrawlers.com/
landrover4wd is offline   Reply With Quote
Old 10-04-2010, 05:35 PM   #15
hey guys im getting a cc01 and i want some upgrades ive sorted the wheels there the same in this pic but black. so can some one show me where i can get those bars under neath the truck in this pic cause standad there plastic so i want better cheers
dannydriftking is offline   Reply With Quote
Old 10-04-2010, 10:05 PM   #16
People have had success making links using axial links or traxxas links, rod ends are both 3mm size(not sure tho), hope this helps
LJ_24 is offline   Reply With Quote
Old 10-04-2010, 11:44 PM   #17
That pic is a custom chassis and not a CC01 just so you are aware. GPM make a rear arm kit and I highly recommend it but you can also make you own as a lot of people have done on here using some threaded rod and link ends.
rustykaos is offline   Reply With Quote
Old 10-06-2010, 10:06 PM   #18
x2 on its up to you on the body you use...Mine is mounted with styrene posts with screws from under the chassis...no screws on top..and pretty stock these rigs do run over lots of stuff...
vid
http://www.youtube.com/watch?v=Zf12bXLAetU
bearings are not a must...but sooner or later the bushings will wear out...I got a set of bearings from the bay, ran me only like 10 bucks..
I make my own links using all thread and tube and traxxas rod end kit #1942.
squatch71 is offline   Reply With Quote
Old 10-09-2010, 05:54 PM   #19
^--That rig is begging for 1.55s and DGs.
rampage is offline   Reply With Quote
Old 10-12-2010, 02:11 PM   #20
Same issue with mine, there at the end of the vid. Not enough front weight and a tad top heavy.
bent is offline   Reply With Quote
