![]() | #1 |
Newbie Join Date: Feb 2010 Location: dover nh
just bought my first cc01 love it but cant get the noise out of the gear box im running bearing and a little grease i have no signs of rubbing any ideas ![]() |
![]() | #2 |
Quarry Creeper Join Date: Sep 2007 Location: New Zealand
Did you lock the front gearbox ? Is so is the cover for the box sitting down straight ? What kind of noise is it ? Is it constant or only at certain points ? Does it do it in forward and reverse ?
![]() | #3 |
onley forward it sounds like a scream
![]() | #4 |
![]() | #5 |
![]() | #6 | |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
| ![]() Quote:
its kind of hard to understand what the problem is with so little information. | |
![]() | #7 |
Wel the only thing I can think of is you have put the 20T pinion on but put it in the 16T holes ? which would make the pinion tight against the spur gear and cause it to scream. As grumpster1980 said without much info its pretty hard to help
