08-17-2010, 12:21 AM | #21 |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
"I think the gear meshing is a bit noisy. I'll have to double check fittings. " Don't worry about the "Gear Noise", after a couple runs it quiet's done. Change the grease after the third or fourth run, and it will be silent. |
08-17-2010, 10:30 AM | #22 | |
Pebble Pounder Join Date: Jun 2009 Location: Canada
You were the one Grumpster who inspired ME to do this project Back to business... No I've decided not to use the posts for scale purposes. Some guys here at the machine shop had some scrap U-PVC sheets/blocks so they cut me a couple of rectangular pieces. I'll post pics up soon about this. Great idea on the GPM steering upgrade...the stock steering has too much play! I will be purchasing the rear link system as well. I've done the simple DIY mods like removing extra material on the hub carriers for extra suspension travel, locking the front diffs by jamming the 3rd spider gear where its not supposed to be, etc. I'd like to get some new shocks as well. I was looking at the Gmade 80mm or 90mm G-Transition shocks. What do you think? | |
08-17-2010, 10:32 AM | #23 |
| Oh good thanks! I guess things have to 'seat' after some runs. I'll change the grease up too after a few battery packs.
08-17-2010, 03:09 PM | #24 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
I think the rears are 70mm and GPM sells replacemnts that are aluminum and threaded I would leave the fronts as is. I only used posts in the rear and they are hidden by the rear canvas cover. I am looking forward to see how you mounted yours. Sweet looking build! any progress on the paint?
08-17-2010, 10:59 PM | #25 | |
I have painted the bumpers and wheel wells black so far. It has been very humid here and would have made painting a bit difficult using an airbrush (I'm an airbrush newbie). I'm using Createx paint. Thanks for the support! | |
08-17-2010, 11:02 PM | #26 |
| GPM Steering
So I bought this set to help with my steering slop...and man it is sloppy! I've heard good things from GPM upgrades for the CC01. I got in beautiful black! |
08-17-2010, 11:05 PM | #27 |
| Body mounts
So the machine shop guys at CancerCare had some scrap blocks/sheets of U-PVC that is pretty hard....but easy to drill through. They were able to cut some rectangular pieces. These sheets of U-PVC could be used as side plates for a chassis...it's that durable. They use this stuff for making all kinds of stuff for immobalizing patients during radiation treatment. Any ways here are the front and rear pieces. They aren't drilled all the way through. I left about 1/8" at the end. Will be attaching foam to the lexan body with velcro on one end and the other half going to the body mount blocks. I still have to adjust the height by cutting the posts down. I hope it works. Wish me luck! |
08-17-2010, 11:47 PM | #28 |
Quarry Creeper Join Date: Jan 2009 Location: Pacific Northwest
Thats a great body mounting idea! Im going to try it myself. My Pajero didnt come with that lower plastic part that attaches to the chasis like a strut bar. Any idea which parts back that may be in so I can pick one up for my build? Thanks! |
08-18-2010, 05:06 AM | #29 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
Those mounts also come in the land cruiser box as well and I would assume any other lexan bodied cc01 version.
08-18-2010, 07:40 AM | #30 | |
The part number for the plastic parts set that includes the braces is: "M" Parts x2 19115264 (you'll need 3 x 12mm self tapping screws to attach to body) For the posts it is: "D" Parts x1 19005741 (you'll need 3 x 10mm self tapping screws to attach to the body mount brace) | |
08-18-2010, 10:29 AM | #31 |
Excellent info! Thank you! |
08-18-2010, 02:46 PM | #32 |
Rock Stacker Join Date: Jun 2010 Location: buffalo
Great Job! |
08-21-2010, 10:39 AM | #33 |
| Elite Forces
I have some ideas...I think I'm going to make a very basic cock pit area for a driver and dash board. I have some ideas using more U-PVC, paper and printer, steering wheel, foam, and a willing 1:18 scale figure...oh and a gunner in the back. Driver Gunner |
08-21-2010, 10:42 AM | #34 |
| Cobalt60 Sand paint! So guys after a couple of Corona and limes I finished painting the Mog with my custom paint blend Cobalt60 Sand (patent pending ). Since Createx paint is water soluble I backed it with Tamiya's gunmetal lexan paint and then flat clear. All I have to do is get the decals on and then paint the outside with flat clear to get that true military look. I'm recycling the window masks from painting inside to the outside of body to retain the glassy window look after applying the flat clear. With the left over paint I sparsly painted the netting. I still have to install the metal eyelets in the net and hooks onto the body. I think it looks dope! Last edited by Evandiego; 08-21-2010 at 10:47 AM. |
08-21-2010, 02:52 PM | #35 |
I just saw one today that color out at MOG FEST! Looks great!
08-21-2010, 10:08 PM | #36 |
Looking good dude~
08-23-2010, 03:16 PM | #37 |
Hey Guys So I've mounted the lights, short snorkel, cage, netting, etc. I'm not to particularily happy with the durability of the Createx paint. It scratches easily and so now I'm going to have to touch it up. Decals are on and I hate putting on decals. It's not completely done yet but I've done a mock up on the body mount but because the hood is sloped it makes it a little tricky. I'll be using a combo of high density foam and more U-PVC. I'm not going to lie the body is heavy. I'll just have to offset the top heaviness with lead weights in the rims and chassis. |
08-23-2010, 09:09 PM | #38 |
Rock Crawler Join Date: Feb 2010 Location: costa rica
Very nice so far, very scale looking. I'll keep an eye on this unimog, just want to see it finished
08-25-2010, 02:17 PM | #39 |
| Body is on! Body mounted on the Chassis. Still gotta do some terrain testing and munitions testing. First a real 'Mog 406: My 'Mog |
08-25-2010, 02:24 PM | #40 |
| Some notes...
I couldn't wait to install the body that I forgot to add the mirrors! Lol! I'm gonna get some black wheel nuts as right now they don't look very scale. Would the Axial wheel nut covers work? I've seen the RC4wd ones but they are $20 online plus shipping and the Axial only $7 at LHS. What do you guys use? Other things I'm waiting for is the GPM rear link upgrade and GPM rear shock mount brackets...all in gunmetal since they ran out of black. It'll still look sick. I'll take more up close and personal pics of the detail on the body. Will post soon. Thanks for looking everyone! |
