Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: My daughters new Bronco.
Old 04-15-2011, 08:40 AM   #21
I like the stance of your other bronco! I guess 4mm it is. I built a led harness last night and got the front and rear lights in.
I don't know why photobucket is jacking up my pics, but I'm trying another site to get them back up.
seabeejeep is offline   Reply With Quote
Old 04-23-2011, 09:57 AM   #22
So I decided not to do the spacer mod for front lift. Instead I pulled out the dremel! Ground away ALOT of the c hub and some of the arms. When I put it all back together I realized the upper arm was now limiting my down travel. So I pulled out som traxxas rod ends and links and mad new upper arms. I have more travel than I need now.
For front shocks I used som RC4WD 80mm scale dual stage shocks.
1. No oil just a drop of wd.
2. ditched the dual springs used MRC silver spring
Now the the front suspension is nic and soft and I get plenty of ride height.
I also install a CB antenna in the rear, spare tire, towstraps, and a custom brass stinger to the front plastic bumper.
I'll get up some new pics later today.
