07-24-2011, 09:51 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Mississauga, Ontario Canada Eh!
| Jeep Wrangler build
I just picked up a previously loved CC01 on the boards here. After seeing some scale vids on Youtube I knew I had to jump right in. It was in pretty decent shape with no major issues and was box stock. I gave it a few runs in stock form and knew I couldn't leave well enough alone. So I ordered up some goodies to start with, RC4WD 1.9 Rock Crushers, Eagle 1.9 rims and a Venom 60T motor. The Rock Crushers are big on this Jeep, but is still do able in scale form. It has taken alot of cutting, lifting and modding to get them to run without binding or digging into the body or chassis. There is a very little bit of rubbing on the body but I can live with it for now. Here's the Crushers on the stock rims with alittle lift (slight body in the front and TLT rear shocks) And heres the after with rims and lots of tweeking with more mods on the way. Next on the list is: GPM BB steering - Already on order GPM Rear 4 link/shock mounts GPM Steel CVD's - Next on the list Custom 4 link rear Paint and detail the body 3racing Winch Remove the brick Custom skid plates |
07-29-2011, 03:30 AM | #2 |
Rock Crawler Join Date: Jul 2008 Location: Williamston
Liking that hard body. They are getting hard to find and expensive too!
07-30-2011, 12:47 AM | #3 |
Thanks I love this body. I know RPP has them for not a bad price. I just ordered a SCX10 Honcho and am really considering ordering the same Jeep body for it. I love the detail on it. This body will (fingers crossed) get repainted this weekend. |
07-30-2011, 09:48 AM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: Portland
The body is worth more (in my opinion) if it does not have the mounting holes on the bottoms of the running boards (meaning its original release and not the one shared with the CR-01) I had one of those bodies, but sold it because it was too far gone for me to feel like restoring. |
07-30-2011, 06:41 PM | #5 |
Well instead of painting the body today, my buddy came over and got him hooked on crawling. We went down to the local park and found some decent places to play. Opps The real one Couldn't resist having some 1:1 fun afterwards |
08-01-2011, 09:25 PM | #6 |
Got around to painting today The blue looks dark in the pics but it really pops in the sun and in real life. Very very close to the 1:1 above. Just need some more little details to finish it up. I'm in the process of fabing up a aluminum skid for it (to hide the brick removal), have those pics up soon. Enjoy You can kinda see the true color here. |
08-03-2011, 01:20 PM | #7 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
looks Good! I love my Jeep Wrnagler Here is my Jeep when it was new out of the box It has been beat and lots of mods since then but I still love it! My only grip is the sloppy steering (even with the GPM kit) and bump steer from hell Its been 4 linked GPM steering kit GPM dog bones GPM knuckles Bearing set RC4WD Steel OEM Bead locks RC4WD Rock Crushers Junfac Driveshaft Junfac under skid plate and some stuff I probably forgot about. They also have many CC01 upgrades http://www.junfac.com/shop/index.php...1&keyword=cc01 Here is a more recent picture (same rims just painted them black) Here is the Junfac under skid plate and drive shaft I like Junfac better than GPM and wish I would of bought Junfacs 4 link because it is a better design. Last edited by Grumpster1980; 08-03-2011 at 01:46 PM. |
08-09-2011, 03:04 PM | #8 |
Looks good Grumpster Digging that military theme. I cut that nasty brick off and made a aluminum skid plate (runs from the back of the bottom skid right up to the body mount). Works really well and with it being one piece it allows the front end to just smoothly slide over stuff, no more hang-ups. And where is all began....... |
08-12-2011, 01:22 PM | #9 |
Thanks! I ended up adding the stock steering back in the GPM one was not working anymore. I will need some plastic weld to fill a screw hole on the tub chassis because it has stripped out. I will re tap it and hope it will hold. I also have a bunch of bling on order from JunFac. They have some cool add on parts for the CC-01 Thanks for sharing your pictures! |
08-12-2011, 09:02 PM | #10 |
Don't waste time trying to save the threads in the chassis. Drill them all the way through and run a long 3MM screw through the cover/tub and put a nut on the other side. |
08-13-2011, 12:37 PM | #11 | |
I would have done that but its right under the gear box and that would be a bad place to drill I ended up using a slightly thicker screw and that did the trick. I got my JunFac parts in and I know they might get hung up on the rocks but I am a sucker for bling! and it does looks good! Front Skid Side Bars Rear Skid Plate JunFac makes some great products and everything bolted up perfectly. | |
08-13-2011, 09:34 PM | #12 |
I like the look of that Junfac stuff I wouldn't mind their 4 link and middle skid setup. I just got my SCX 10 today and started building it So far I'm pretty impressed with Axial and the quality of their products. Its going together like butter. I will be converting it to a Jeep XJ.. The CC-01 goes out for its first real outting tomorrow, hoping it all goes well. I'll post up some pics after. |
08-13-2011, 09:39 PM | #13 | |
I bought the Rock rails from Junfac for my SCX10 as well. | |
08-14-2011, 07:13 PM | #14 |
Looking good man. I got the CC01 out for its maiden run today on some real rocks. I must say I was very impressed on how it ran. The 60T motor with a 16 tooth pinion gave me the perfect amount of wheel speed and torque, the rc4wd Rock Crushers ran great on both the wet rocks and the dirt trails Now on to the pics. These are just a few, I will post a link to my Photobucket account so you can see them all. All that broke was a steering knuckle that was at the end of its life anyways. LOL http://smg.photobucket.com/albums/v6...t%20of%202011/ The location: The first run: After a good day of wheeling: |
08-15-2011, 10:56 AM | #15 |
Sweet spot to 4X4! and cool pictures. Did you have to use longer shocks and stiffer springs to get the rock crushers to fit? I see you had to chop the wheel wells a lot to get rid of the rub. I assume they are 1.9's ? I wonder if they make them in 1.5
08-15-2011, 03:29 PM | #16 |
It was the most amazing crawl spot I have ever been to. Lots of hard comp style stuff and great scale runs too. The trail run was really sweet, very scale and had some really hard spots to make it through. They are 1.9 Rock Crushers, so 4.25 high. I used TLT rear shocks (because I had them laying around) and Tamiya alum touring units for the fronts, swapped in some Associated black buggy springs to soften them up. I did have to chop the front fenders on the chassis to stop rubbing, the offset on the rims doesn't push the tire out enough though so on tight turns it will rub the inner chassis a bit. They do make the tires in 1.5 but I enjoy the the 1.9's (close to scale 40's) on the Jeep. Just need to add some weight to the front and the wheels and adjust the left rear preload to get rid of the torque squat. Now I just wish there was a scale event around to run it in. Just have to finish the Axial off now so I can take it out there. |
10-05-2016, 01:55 PM | #17 |
Newbie Join Date: Sep 2016 Location: United Kingdom
| Re: Jeep Wrangler build
[QUOTE=DV8ion;3224602]Looks good Grumpster Digging that military theme. I cut that nasty brick off and made a aluminum skid plate (runs from the back of the bottom skid right up to the body mount). Works really well and with it being one piece it allows the front end to just smoothly slide over stuff, no more hang-ups. Sorry to bring this thread back to life, if you cut the brick off, how ha e you mounted the wrangler body? I have one and want to chop the brick away, but I've read somewhere not to do it if o have the wrangler body. Thanks Paul |
