12-08-2011, 11:25 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Anchorage
| How to lock front diff?
Hey guys! I just bought a used CC01 and was wondering how to lock the front diff.... Also, the stock tires really suck as theyre hard (that's what she said) so any suggestions on an aftermarket tire that's the same size as stock? Thanks guys... I have an FJ Cruiser body on the way and I'll be building a cc01 fj cruiser to go along with my SCX10 FJ Cruiser |
12-09-2011, 12:00 AM | #2 |
RCC Addict Join Date: May 2011 Location: Utah County
1.55 dirt grabbers are like 3.1" tall. That's probably pretty close to stock tires. I run 1.9 dirt grabbers on my fjcruiser cc01. They're like 3.8". I want some 3.3" tires on 1.55t wheels. You could lock your front diff with hot glue. Or I used to lock drifters with silly putty. But that's different. But you can get creative. Or buy a locker Haha. Sent from my ADR6400L using Tapatalk |
12-09-2011, 01:23 AM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: Oakdale, MN
| You can lock the front diff by ordering another “G” parts tree and use part # G5 to lock the front diff. If you don’t want to order another G parts tree you can take one of the small bevel gears and slide it in-between the other two and it will lock the Diff. For tires in the picture for height comparison from left to right: Tamiya Rock Cruiser M/T’s RCD4WD Prowler XS 1.9 tires. S.D.I. Trail Doctor; smaller size than the XL’s, 1.9 S.D.I. Trail Doctor LX, 1.9 tires I am currently using the Prowlers and love them. |
01-26-2012, 05:49 PM | #4 |
Newbie Join Date: Jan 2012 Location: Four Corners
| Re: How to lock front diff?
The prowler has a good look to it and sounds like you are happy with them.. Might just use those.
01-26-2012, 05:54 PM | #5 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
RC4WD 1.9 Rock Creepers work well. Slightly taller than stock.
01-26-2012, 06:35 PM | #6 |
Rock Stacker Join Date: Jan 2011 Location: Courtland, VA
Pull the diff apart and put the gears in like this . It's Free! The side of the gear that is facing you in the pic my need a slight notch for them to mesh properly so the diff will go back together. |
02-06-2012, 07:55 PM | #7 |
Newbie Join Date: Oct 2011 Location: ojai
you can do the same thing with the front diff as the picture above |
02-07-2012, 02:10 PM | #8 |
Newbie Join Date: Jan 2011 Location: Los Angeles
i used beadlocks and tires from my MRC. should be able to find them real cheap in the classified section.
02-07-2012, 02:32 PM | #9 |
02-07-2012, 08:56 PM | #10 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
| Re: How to lock front diff? hot glue has yet to let me down.... tires Land Rover Defender 1.9" tires set with inserts Tamiya | eBay fit without chassis mod 96mm tall just hair over stock,good grip, not hard |
