Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: CC01 Jeep Wrangler Upgrade
Old 07-05-2012, 01:01 AM   #1
Default CC01 Jeep Wrangler Upgrade
On your opinion which is better package upgrade in these list
1. CC-01 Disc brake metal kit + aluminum rim, Rc Channel - The Worlds of Rc Car Parts
2. CC01 4-Link suspension conversion with skid plate [J100210] : JunFac.com
3. GPM ALUMINUM CONVERSION KIT SILVER fits TAMIYA CC-01 CC01 | eBay
your input based on your experienced for the said package will be appreciated
4j's is offline   Reply With Quote
Old 07-05-2012, 07:37 PM   #2
Default Re: CC01 Jeep Wrangler Upgrade
#2, but add a GPM alloy steering upgrade
pardonmyn00b is offline   Reply With Quote
Old 07-06-2012, 12:02 AM   #3
these would help also
Tamiya CC-01 Front Steel Univeral Drive Swing Shafts CVDs
wkxtreme is offline   Reply With Quote
Old 07-06-2012, 10:05 AM   #4
1. just womdering if the GPM shocks sre oil damper or just adjustable any idea or review about it?
2. looking up and down if i need to seal the front gear and differential cover as well as the rear differential cover. If yes what sealer you can recommend?
Old 07-06-2012, 11:17 AM   #5
I'm really digging that 1st option you have there...the metal axle kit/ disc brakes...I may just have to get one...LOL My CC-01 I have done the rear 4 link (GPM shock mount and made my own links) and the GPM alloy steering (like Noob suggested). Both have made a big diff in what it is able to handle but more mods are still needed. front CV shafts are almost a must if you raise the front of the truck and mod the knuckles for more steering. And if you are running any real weight in the wheels then I feel a GRU is needed (I wouldn't mind the rc4wd 2:1 or 3:1). For water proofing the axle and gear boxes I just packed mine with Marine Grease and it works pretty darn well.
DV8ion is offline   Reply With Quote
Old 07-06-2012, 12:41 PM   #6
I have the Junfac kit on my Mog. It's a nice kit, but with the skid plate it ends up making it seem a bit "low" in the center. I do like the kit, though, and for me that lowered clearance isn't a big deal because I'm using it for only trail driving, and not any serious crawling or climbing.
Gimpdiggity is offline   Reply With Quote
Old 07-06-2012, 11:29 PM   #7
Thanks for all the input.
GPM Steering and GPM Univeral Drive Swing Shafts, I'm about to order and bearings as well
Regarding the GRU, I read that you need to modify or costumize your car to make this works. Im not good in modifying parts
CC01 Jeep Wrangler Upgrade - Similar Threads
Tamiya Jeep Wrangler CC01 Kits IN STOCK RPP Hobby RPP Hobby 0 10-21-2011 11:29 AM
cc01 Jeep Wrangler kit any good? grimgard Tamiya XC/CC01 7 10-10-2009 01:03 AM
