09-20-2012, 07:29 AM | #1 |
Newbie Join Date: Nov 2005 Location: Somewhere
| Rear axle
I have a new axle that I built for a project that I was going to use a CC-01 axle for. The axle in my CC-01 has no side-to-side play in the axles, however this spare one does. I can grab the wheels and push/pull them about 1/16" in and out. I've taken it apart and can't see anything that I missed, so I don't know if its a manufacturing issue or what. Would it hurt anything to put a shim in between the outer bearing and the drive pin to make the axle stay in place? Any ideas? |
09-20-2012, 03:56 PM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Brisbane, Australia
| Re: Rear axle
Shims should be fine, I run them on my front hubs to kill the side to side slop.
09-20-2012, 03:59 PM | #3 |
| Re: Rear axle
OK, cool. I was going to build a "gasser" pickup using a Midnight Pumpkin body, but the axle is a bit wide unless I use low-offset wheels and then it looks silly.
09-21-2012, 02:58 AM | #4 |
| Re: Rear axle
As in drag strip 'gasser'? If so very cool and post some pics up here anyway!
Rear axle - Similar Threads | ||||
Rear steer on rear center VP axle | irokcrawl | Axial Wraith | 5 | 09-23-2012 03:44 PM |
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits | LetsHandleit | Axles, Trannys, T-case | 41 | 06-24-2012 06:57 PM |
Rear steer lockout so you can still mount stuff on rear axle | bill400ex | Duratrax Cliff Climber | 9 | 02-16-2010 07:49 PM |
