Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: JunFac shaft for CC-01
Old 10-14-2012, 06:23 AM   #1
Default JunFac shaft for CC-01
What is the lenght of the JunFac shaft that you are installed on your rigs?
I intend to collect some data for the various wheel base, what lenght for Jeep/Pajero, Bronco and Toyota ?
cornel4web is offline   Reply With Quote
Old 10-14-2012, 04:08 PM   #2
Default Re: JunFac shaft for CC-01
Am I missing the point here? JunFac make a shaft specifically for the CC-01 and all CC-01s are the same in terms of driveshaft length.
derb is offline   Reply With Quote
Old 10-14-2012, 09:11 PM   #3
The Honda CR-V and Touareg are the only ones that use longer driveshafts. All the others should use the shorter version.
83imp is offline   Reply With Quote
Old 10-14-2012, 09:17 PM   #4
Hardened Universal Shaft (107-142mm) 5mm hole [J90033] : JunFac.com That is the same size in all dimensions as the shaft that is sold specifically for the CC01.
However, if you want more length, go for Hardened Universal Shaft (120-155mm) 5mm hole [J90034] : JunFac.com. I have that second one in my CC01 now after having the 'made for CC01' unit in and it's much better. Much more shaft up inside the other one, no way it could come apart on a CC01. I've only had two because I lost half of the first one and went to the local hobby shop instead of waiting for JunFac.
Old 10-14-2012, 10:05 PM   #5
...as I know the Jeep and Pajero are the short wheelbase versions, the Touareg is the long version and the Bronco and Cruiser use intermediate wheelbase lenght...and I see people who get JunFac 4 link upgrade, are using different shafts...
Old 10-14-2012, 10:10 PM   #6
I ran the stock shaft on my Landcruiser CC01 with the JunFac 4-link kit. Was just long enough to not be pulling on the axle pinion input. Like 1mm of play at full droop.
Old 10-15-2012, 02:39 AM   #7
Thanks...can I have a pics of you fully extended and compressed?...Thanks a lot and sorry for my noobs questions.
Old 10-15-2012, 03:59 AM   #8
My chassis is over at MoonUnit's place at the moment. I'll try and get some pics this week.
Old 10-15-2012, 06:16 AM   #9
thanks...
Old 03-07-2013, 11:58 AM   #10
I'm a little confused on what shaft I can out in my Toaureg CC01. This site says something different then what the thread says.
http://www.rcplanet.com/Junfac_Harde...p/jun90034.htm
Any help would b great!!
Sent from my iPhone 5 using Tapatalk
Smileyboy is offline   Reply With Quote
Old 03-07-2013, 05:03 PM   #11
It should be the 107-142mm version, but a little shorter wont hurt you.
Old 03-07-2013, 05:11 PM   #12
That helps. Thx!
Old 10-19-2013, 05:51 PM   #13
My Toaureg shaft is about 150mm
Punisher Shaft II (120-150mm, 4.72"-5.90") 5mm hole
Ext Punisher Shaft Wheely King 120-150mm 4.72"-5.90"
CaptainScale is offline   Reply With Quote
JunFac shaft for CC-01 - Similar Threads
Junfac Universal Shaft Tedro Axial SCX-10 10 09-18-2010 12:35 PM
junfac drive shaft LEROY Axial SCX-10 11 09-11-2010 02:39 AM
Junfac drive shaft.... HRDROKN Venom Creeper 15 01-21-2010 12:36 PM
JunFac Universal Shaft AlphaDOG Axial AX-10 Scorpion 14 09-26-2009 12:08 AM
new shaft from JunFac vcar1 Tamiya CR-01 25 02-10-2009 09:06 AM
