12-12-2012, 01:23 AM | #41 |
Rock Crawler Join Date: Jul 2012 Location: Brisbane, Australia
| Re: New to Rc trucks and the CC01
It looks like it will be alright just judging from your pic. Give it a try and let me know how you go.
12-22-2012, 12:19 AM | #42 |
Newbie Join Date: Nov 2012 Location: Melbourne
So I got the Dremel and drill out, did a bit of binding resolution. Spaced the upper control arm and ground out a little bit off the inside of the lower control arm. It all resulted in about 2-3mm extra travel/height. The left hand side is the result of the work. |
12-22-2012, 03:57 AM | #43 |
Sounds like a small number, but looks pretty sweet in that pic. How did you space out the upper control arm?
12-27-2012, 06:06 PM | #44 |
Just spaced it it with 3mm washer/spacer between ball joint and body.
12-27-2012, 06:08 PM | #45 |
Fitted winch and bullbar this morning. ...next, bash plate. |
12-27-2012, 08:40 PM | #46 |
Oh right, yeh I understand now thanks.
01-01-2013, 02:28 AM | #47 |
Latest pics of the build, shell on, roof rack, lights, new bash plate... |
01-01-2013, 03:07 PM | #48 |
Awesome work on the shell dude, the whole rig looks great.
01-01-2013, 05:21 PM | #49 | |
Quarry Creeper Join Date: Feb 2008 Location: Oakdale, MN
| Re: New to Rc trucks and the CC01 Quote:
I'm confused...Where did you place this washer? Picture? As for the whole truck, I love what you did! It looks awesome and with all that travel it does not look like you have a CC-01 chassis.... | |
01-01-2013, 10:25 PM | #50 |
Washer between the tub and the screw in ball joint that is upside down.
01-02-2013, 06:25 AM | #51 |
Here's a pic. |
01-02-2013, 04:31 PM | #52 |
So I locked the rear diff yesterday with the parts provided. How do I lock the front? Anyone got pics?
01-02-2013, 05:37 PM | #53 |
Use the 3x spider gears that would normally go into the rear diff. With 6x spider gears in there it's locked up tight. |
01-02-2013, 07:24 PM | #54 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
I've never been able to get the extra gears in one of these. I gave up and stuffed Yeah Racing spool in mine. Same effect, but mo' money.
01-02-2013, 09:01 PM | #55 |
If you sand the back side of the spider gears they fit in much more nicely.
01-02-2013, 09:40 PM | #56 |
I ended googling it. You actually only need to put one in there. Thanks
01-02-2013, 09:45 PM | #57 |
I cheated even more and just flipped one of the three gears to inbetween the other two. I've had no issues, but the front diff is not exactly balanced that way.
01-02-2013, 10:38 PM | #58 |
Newbie Join Date: Jan 2005 Location: Bradenton
You can remove slope in the GPM steering by filing the linkage bushings shorter to where they just rotate back and forth with no up and down deflection. Also, The locking spider gears fit in the front diff better if you notch out the gear teeth at the back of the spider, get rid of the round flange that goes from tooth to tooth. It will nestle down better into the other spider gears and allow you to screw the diff together with less difficulty and let the diff gear rotate freely in the front gearbox.
01-03-2013, 12:35 AM | #59 |
Yeah it works well. However now the turning circle is twice as big, so thinking of maybe unlocking the front to keep the better handling.
01-03-2013, 01:28 AM | #60 |
It's really not worth it man, when just one of my front CVDs broke the truck was useless on anything except flattish ground. These rigs lift the front corners pretty often so you need all the front traction you can get.
New to Rc trucks and the CC01 - Similar Threads | ||||
10 Trucks Scaling at Upper Peirce Reservoir - RC4WD Axial Wraith SCX10 Tamiya CC01 | boolean21 | Scale Videos! | 4 | 09-27-2012 05:16 PM |
14 Trucks Offroading : Trail Finder 2 CR01 CC01 SCX10 Dingo Wraith M923 6x6 Defender | boolean21 | Scale Videos! | 2 | 09-12-2012 09:20 AM |
9 Trucks Offroading Unimog u300 M35 Custom Axial Wraith Tamiya CC01 scx10 Honcho | boolean21 | Scale Videos! | 2 | 06-05-2012 07:15 PM |
11 Trucks Scaling: 6x Land Rover Defender D90 CC01 Unimog 3x Axial Wraith Summit | boolean21 | Scale Videos! | 0 | 02-25-2012 09:52 AM |
[Video] 14 trucks Crawling - CC01 SCX10 Unimog 6x6 Man Truck RC4WD Timberwolf Honcho | boolean21 | Scale Videos! | 0 | 11-15-2011 10:04 AM |
