03-29-2013, 11:29 PM | #1 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
| Outrunners
My brother, who is amazing at crashing RC planes, stopped by today and gave me a couple of BL outrunner motors. They're both about 950kv and have the correct mounting holes. Pretty cool so far. The only hitch is the 5mm output shaft. I was thinking about drilling out a 20t pinion to fit, but realized the pinion for my GRU is way smaller, so that's a no go. Any thoughts on getting the output shaft down to size using a small vise, a Dremel and some files?
03-30-2013, 01:04 AM | #2 |
| Re: Outrunners |
03-30-2013, 01:06 AM | #3 |
| Re: Outrunners
Thatīs what i did, filed down the shaft enough to accomodate the pinion, pretty easy |
03-30-2013, 12:37 PM | #4 |
How did you keep the metal filings out of the magnets? Seems like it will get messy
03-30-2013, 02:01 PM | #5 |
| Re: Outrunners
Put a plastic bag around the motor, poke just the shaft through and that will minimise the metal shavings on the magnets.
03-30-2013, 11:45 PM | #6 |
Quarry Creeper Join Date: Feb 2011 Location: Forbestown, CA
| Re: Outrunners
;) had this issue pushing a pro4 5.5t into mine i used this TowerHobbies.com | Axial Pinion Gear 32P 12T Steel 5mm Motor Shaft -- make sure you find one with the correct pitch though.
03-31-2013, 01:58 AM | #7 |
Is the internal gearing on the rc4wd GRU 32p? I thought it was much finer than that. If it is, this is a great solution. Thanks.
03-31-2013, 02:09 PM | #8 |
| Re: Outrunners
correct this will not fit the normal gru from rc4wd or the little one in the picture, if I was stuck in this spot I would reduce the shaft to 4mm and drill the pinion out to 4mm to keep some meat on both. or find someone to trade your motor with |
03-31-2013, 06:11 PM | #9 |
My other ideas, if I don't turn it down myself, would find a friend with some proper gear for turning the shaft or drilling out a 20t pinion and eliminating the GRU. I tried drilling out a pinion myself, but it was a little (really) wobbly.
Outrunners - Similar Threads | ||||
Outrunners? | Jeepkid | Axial XR10 | 28 | 10-12-2010 03:09 PM |
High KV outrunners? | theslowguy | Electronics | 6 | 12-04-2009 03:26 PM |
Big outrunners with what? | Brainstain | General Crawlers | 12 | 03-18-2008 03:26 PM |
outrunners. wow... | Slyp Dawg | Electronics | 2 | 12-17-2007 10:17 AM |
new giant outrunners! | microgoat | Electronics | 11 | 11-01-2005 08:42 PM |
