07-06-2013, 11:14 AM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: shelby
| gpm steel cv's
I have read a lot on the aluminum ones but I haven't found much on the steel ones, any body have any experience with them. I'm running a 55t motor without a gru so they won't be heavily stressed. I know the. Yeah Raceing ones are better but I have a lot of Amazon gift cards to burn and all they have is the gpm. Thanx guys.
07-08-2013, 05:31 AM | #2 |
| Re: gpm steel cv's
Well I ordered them, I'll do a mini review after I bash them a while and name the tread accordingly so the next guy with questions doesn't have to wade through countless build treads only to come up empty handed. Awsome search engine here huh lol.
07-08-2013, 08:05 AM | #3 |
| Re: gpm steel cv's
Search engine here is wonky for sure. I have a set on my rig (in this section somewhere) - no issues to date.
07-08-2013, 05:45 PM | #4 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
One hint for searching these forums is to use some google-fu. If you want to find a specific term (and not wait 60 seconds between searches) go to google and enter your search term followed by a site search. it might look like "GPM site:rccrawler.com/forum/tamiya-xc-cc01/" Once you're in it you can refine terms, do Boolean searches, image searches. Really speeds things up |
07-09-2013, 10:51 PM | #5 |
Rock Stacker Join Date: Dec 2012 Location: SF Bay Area
| Re: gpm steel cv's
The GPM steel shafts are a real headscratcher for me when I bought them for my CC01... For one, there are two thin metal shims that come along with the set. Don't know what they are for - they're too thin to serve any beneficial purpose and the inner diameter is too large to correctly sit between the outdrive of the shaft and bearing without falling out. Second, on the bolt end of the shaft itself (where the swing pin meets the dogbone), the circular flange does not run a full circle. This I find also contributing to the shims falling out as well. See pic Last edited by csb510; 07-09-2013 at 10:53 PM. |
07-09-2013, 11:57 PM | #6 |
| Re: gpm steel cv's
Perhaps it goes between the bearing and the knuckle instead.
Last edited by smokinloon; 07-09-2013 at 11:59 PM. Reason: auto corect spelling strikes again |
07-10-2013, 06:39 AM | #7 |
| Re: gpm steel cv's |
07-28-2013, 12:22 PM | #8 |
| Re: gpm steel cv's
A little update. I have been running these pretty hard for a few weeks with a 55t and 3s and the joints are still tight and they are still straight as new, even with a heavy trigger finger. The only thing I don't like is that they aren't very smooth at steep angles so if you lift the suspension it will have "wheel wobble". It seems to be getting better as I drive it so I'm wondering if the rough edges are wearing down.
08-05-2013, 12:03 AM | #9 |
08-06-2013, 05:09 AM | #10 |
| Re: gpm steel cv's
Well I spent most of Sunday chasing a couple of wraiths on the rocks and after a lot of hard falls and rock jumping they still look good. Impressive for only 17$
08-06-2013, 06:29 AM | #11 |
| Re: gpm steel cv's
Yup best upgrade for your cc-01 if you've locked both diffs. I'd look into the sloppy steering next!
08-06-2013, 08:37 AM | #12 |
| Re: gpm steel cv's
Movin the servo up front as I type this, may try a suicide steering setup like you see on the wraith/ridgecrest.
gpm steel cv's - Similar Threads | ||||
Are My 3Racing CV's Ment to Bind THIS Bad? (With Video) | Grouper | Axial AX-10 Scorpion | 2 | 01-21-2012 04:28 PM |
bought some h/r cv's need some wheel adapters | jasonphillips | Tamiya Clod Buster | 0 | 05-09-2010 09:20 PM |
Easiest/Best Place to Order V3 CV's??? | CRAWLKINGIV | Team Losi Comp Crawler | 10 | 04-15-2010 06:21 PM |
New News on my CV's | kikcaffine | Team Losi Comp Crawler | 11 | 06-06-2009 12:08 AM |
Anyone Know where i can get some cv's | red4x4 | General Crawlers | 4 | 01-17-2008 06:34 AM |
