07-26-2013, 04:50 PM | #1 |
Newbie Join Date: Jul 2013 Location: elmswell suffolk england
| getting started with a cc01
Hello! I'm set on buying a cc01, modifying it with a blackfoot shell (ive got a spare blackfoot shell) and going trailing! Im lucky to have woods etc around me but I'm unsure on a few bits... I race 1/12th rc bangers and have been into rc for probably 20 years so I know whats what! my questions are will the kit wheels take the 1.9 tyres? how do you raise the body and what else would be worth doing? I like the detail of the Tamiya kit hence me choosing it! Any advice would be great! many thanks |
07-26-2013, 11:45 PM | #2 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Hi. The wheels are 1.9, so that bit's easy. The body posts are fairly adjustable. Also easy. Other than that, the usual RC stuff applies -. Bearings are very vital, remove slop wherever possible, etc. Oh yeah, the stock motor will be way too fast. Grab a cheap 55t and you're golden.
07-27-2013, 11:59 AM | #3 |
| Re: getting started with a cc01
Excellent! So the kit wheels will take the tyres I've seen advertised everywhere! I will also be looking to gain a bit of ground clearance. Are the alloy bits worth having? Any suggestion on which 55t motor is worth getting?
07-27-2013, 02:31 PM | #4 |
If you use a tire designed for a beadlock wheel, like something from rc4wd, it will be a bit tricky to glue to the stock wheels, but it is doable. The alloy bits that are worthwhile are the gpm steering kit and the Junfac links. Almost forgot: if you're mainly trailing, a cheap sealed can motor will do the trick. RC4WD has a line of motors priced at $10 each. Good to get going with and no big loss when they eventually wear out.
07-28-2013, 02:09 AM | #5 |
So can I get a set of different wheels then? Thanks for your help by the way!
07-28-2013, 08:07 AM | #6 |
Yup any 1.9" wheel will work. I like to keep the tires right around 4" or so. Longer shocks will give you a mild lift, and raising the body will help clear those taller tires. If you plan on doing real rock crawling a gear reduction unit is recomended. Stock gearing is just not low enough. Trail running isfine with just a 55t motor.
07-29-2013, 01:20 AM | #7 |
I'm sure I've seen something about more articulation on the back axle using a touring car suspension arm or am I making this up? I've also heard about a shackle mod? What is this?
07-29-2013, 10:53 PM | #8 |
The extra articulation is gained by something called the "magic link" setup. It just adds a pivoting link to the top of the rear dampers to allow them to extend further. It's a great, simple modification. The only touring car based mod I know of is swapping in the TL01A front arms, but that's a bit complex to start with. Here's a link anyway, in case you're feeling brave. Cheers! |
getting started with a cc01 - Similar Threads | ||||
Looking to Get Started | AlienRC | Newbie General | 6 | 07-11-2011 05:51 PM |
Getting started | Nitro125 | General Crawlers | 3 | 06-22-2011 06:03 PM |
New here and want to get started! | 87burb | Newbie General | 9 | 04-07-2008 10:37 PM |
just getting started | NeRoMo4 | Newbie General | 6 | 07-18-2007 12:12 PM |
