11-12-2015, 05:36 PM | #41 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
| Re: TeeYota FJC
Not a fj fan but awesome job hard to take my eyes off of your truck might have to find one the hardbodys for the wifes cc01 wrangler |
03-04-2016, 05:08 PM | #42 |
RCC Addict Join Date: Oct 2007 Location: Long Island-Land of one batch of rocks in Sag Harbor and at least one fellow crawler
| Re: TeeYota FJC |
03-10-2016, 05:45 PM | #43 |
| Re: TeeYota FJC |
03-12-2016, 08:50 AM | #44 |
Pebble Pounder Join Date: Jun 2015 Location: Netherlands
| Re: TeeYota FJC
Looks great, love the bumpers |
03-19-2016, 02:25 PM | #45 |
| Re: TeeYota FJC Thank you, they definitely fit the look/feel of this rig. Lids off and doing work! Ok so my "stubby" motor showed up. A vintage Tamiya motor! Its pretty sweet. I shouldn't have to make much modifications to fit it plus the GRU. GRU is 4:1 Clear glass and interior bits seen in the back ground will be installed soon too! |
03-20-2016, 05:06 PM | #46 |
| Re: TeeYota FJC |
03-20-2016, 05:08 PM | #47 |
| **help**
I need some HELP here with this GPM ball bearing steering. Does anyone else have issue with slippage? It is confusing because of the way it is notched, it doesn't seem like it would slip but it definitely does. Any suggestions on correcting? Has any bought the $70 steering set up from Square RC? Any better? Last edited by eddievedder; 03-20-2016 at 05:12 PM. |
03-28-2016, 06:22 AM | #48 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: TeeYota FJC
Nice looking FJ there, I like that stubby motor with the GRU idea a lot!
03-28-2016, 06:24 AM | #49 | |
| Re: **help** Quote:
Hot Racing Tamiya CC-01 Truck RC Car upgrades and Hop-ups | |
04-19-2016, 01:20 PM | #50 |
Rock Stacker Join Date: Dec 2009 Location: Calgary, AB, Canada
| Re: TeeYota FJC Trail Teams Edition Army Green
Wicked build man, looks amazing. Did you build those bumpers for it?
04-19-2016, 07:02 PM | #51 |
Pebble Pounder Join Date: Nov 2015 Location: Northern NJ
| Re: TeeYota FJC
On the GPM steering....I finally noticed a little slippage also....The flats are slightly less flat than they should be. I can slip the joint if I manually push on the linkage, but in normal use, it is not slipping (loctite in joint probably helped it). I am going to try a star washer in there. The sharp edges should bite on the aluminum and hold it in place.... I don;t have a 3mm washer on hand, so I'll report after I get some... I was thinking about some sort of shim, but can;t seem to find what i think might work.....Doesn't seem to be enough material to pin it either. I figure one end can be a "permanent" fix, only one end needs to be disassembled to take apart...looking at that angle too. |
04-20-2016, 05:13 AM | #52 |
| Re: TeeYota FJC
I have the GPM steering on my wrangler build and I can definitely see that it is going to be a problem down the road, the notch is not big enough and it has play in it. I also thought about maybe pinning it somehow. I put the Hot Racing setup on my silver Unimog and it is a much better design. Yeah it costs more, but IMHO, it is much better and worth the price to not have to go back and fix it again. I've thoroughly tested the silver Mog on some serious course and rock and the steering is still as tight as it was when I installed it. |
04-20-2016, 05:19 AM | #53 |
| Re: TeeYota FJC
Eddivedder, what are you painting your chassis with? I like that idea, very cool. I've been out to Sag Harbor before, Greenport too on my boat, it's really nice out there. (I'm originally from CT) |
02-06-2020, 10:47 PM | #54 | |
| Re: TeeYota FJC Quote:
I used the matching paint for the body. I’ve done two CC01 chassis and never again. It’s a pain. Next time you’re in sag harbor, reach out to me! Sent from my iPhone using Tapatalk | |
02-06-2020, 10:53 PM | #55 |
Fine tuning this old horse It’s heavy. It’s IFS. Is a CC01. But it’s Tamiya strong and geared for some fun crawl control. This thing is a blast. Most capable CC01 I’ve ever toyed with. Sent from my iPhone using Tapatalk |
02-07-2020, 07:09 AM | #56 |
Quarry Creeper Join Date: Feb 2008 Location: Oakdale, MN
Great looking build and don’t see too many folks running the SDIs any more. Love it! Sent from my iPad using Tapatalk |
02-07-2020, 10:34 AM | #57 | |
| Re: TeeYota FJC Trail Teams Edition Army Green Quote:
Thanks. Honestly I love the old school stuff. The SDI Trail Docs super soft are a great self cleaning mud tire. The compound isn’t nearly as “sticky” as what’s around today but I love the tall skinny look. Sent from my iPhone using Tapatalk | |
05-24-2020, 03:26 PM | #58 |
The locked and loaded FJ CC01 took a spin on the backyard course version 2.0. This this is so surprisingly capable. Sent from my iPhone using Tapatalk |
05-25-2020, 04:45 AM | #59 |
Newbie Join Date: Jan 2019 Location: N Ireland
| Re: TeeYota FJC
Looks great! What spring/shock set you have there? I just installed Tamiya barrel spring set with my CC-01, it is much better. However, I noticed that these stock dampers could have been a bit longer, as there was a little more suspension travel when I took the shock off. |
05-26-2020, 10:58 AM | #60 | |
Those are RC Channel shocks for the CC01 with vintage tamiya medium yellow rear buggy springs. It’s a great combo. Sent from my iPhone using Tapatalk | |
TeeYota FJC - Similar Threads | ||||
fjc | bikerpyro | 1.9 Scale Rigs | 4 | 03-03-2012 12:17 AM |
who makes the best fjc body | havik | Paint and Body | 8 | 12-23-2008 02:35 PM |
FJC or Taco | Blind4454 | Paint and Body | 3 | 09-03-2007 12:43 PM |
Another FJC body I havent seen on here yet | RTrac1 | Paint and Body | 21 | 09-02-2007 02:48 PM |
New CC-01 project...Oh yea, it's not an FJC! | its%*&#*%!brokenagain | 1.9 Scale Rigs | 12 | 02-07-2007 11:29 AM |
