01-13-2014, 05:20 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: 419 area
| my first cc01!
I just bought it yesterday for $80 as a artr, it had already been 4 linked, metal high torque servo, 550 21t motor, and a set of like new mud slingers. this how it looked when I first got it...not to pretty! I really didn't like the look of it so I cut the slingers, trimmed the body a little, took the lights out, and gave it fresh coat of black paint for now! I think it looks way better now....and what is a good shock setup to use on this, right now it has mismatched springs on it and they are stiff almost zero flex. so for now this is all I have but I do plan to keep working on it! Thanks for looking |
01-13-2014, 10:28 AM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Ravenna/ Sault Ste. Marie
| Re: my first cc01!
Definitely looks better in black. looking forward to what is to come. |
01-13-2014, 02:23 PM | #3 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
| Re: my first cc01!
What was going on with the surface finish when you got it? It appears to have been a mix of stucco and packing tape.
01-13-2014, 06:28 PM | #4 |
| Re: my first cc01! |
01-13-2014, 06:31 PM | #5 |
| Re: my first cc01! thanks! im really looking forward to taking it out on the trails, it will be on the back burner as far as mods go because my main priority is the scx10 but I will drive it every chance I get!
01-13-2014, 06:33 PM | #6 |
| Re: my first cc01!
what would be a decent motor to run? right now I have a 20 turn in it and it is a little to fast I think and the motor gets HOT! it started smoking today so I have to be careful how I run it.
01-13-2014, 09:06 PM | #7 |
| Re: my first cc01!
Cheap 55T motors are your friend. I'm using a Lowbucks racing (copy of a generic can or a Tekin) I got for $10. RC4WD has sealed cans for $10. Worth looking at, if only to gaige how fast or slow you want to make it.
01-13-2014, 09:44 PM | #8 |
| Re: my first cc01!
my main concern is how hot the motor will get would a 27t or 35t motor be ok? I don't want it super slow about a jogging speed is what im looking for. i pulled the 20t out and put in a 550 size 21t to hold me over. i just hope it doesn't get super hot.
01-13-2014, 09:57 PM | #9 |
55 will do jogging speed. Many install 4:1 gear reduction, as they feel 55 is too fast.
01-13-2014, 09:57 PM | #10 |
| Re: my first cc01!
A 55t is good for a jogging pace. 16t pinion.
01-14-2014, 04:26 AM | #11 |
| Re: my first cc01!
ok thanks I will get a 55t, and I am running the 16t pinion.
01-14-2014, 06:28 AM | #12 |
01-24-2014, 05:38 PM | #13 |
Rock Stacker Join Date: Oct 2013 Location: in my house
| Re: my first cc01!
well this little CC-01 has changed hands again, its mine now. I'm in the process of working the slop out of the steering. My first cc as well. One question for you more experienced guys, it's got a metal spur gear, steel I think, and a 16t pinion and the gears are too tight. What pitch are these gears? i've seen conflicting results of .6, .8 and mod 1
01-24-2014, 06:20 PM | #14 |
| my first cc01!
If it's stock pitch gearing, they are .6 mod. Sometimes, they are erroneously referred to as "48p metric". Robinson Racing uses that designation. The best quality .6 pinions I've found are Kawada and Robinson. Haven't tried Tamiya's own hardened pinions. JUST NOTICED...you said metal spur...that's probably a GPM piece, which would make it .8 mod. http://gpmracing.com.hk/catalog/prod...464456e6a8b8bc Last edited by monkeyracing; 01-24-2014 at 06:26 PM. |
01-24-2014, 08:56 PM | #15 |
| Re: my first cc01!
yeah that looks like the parts, in black. The gears sound jammed together and it drags hard. I think one of the motor mount holes is gonna stretch a touch. Just finished up a bearing mod for the steering. It's rock solid. 1x4 Aluminum rod, 2 bearings 10x5x4, 2 traxxis drive shaft screws. Lathe the rod to 5mm on both ends long enough to fit through the bearings and both ends of the linkage. Drill the tub to 10mm. Drill the rod and the ends to fit the set screws. I post some pictures up in a little while.
01-25-2014, 06:44 AM | #16 | |
| Re: my first cc01! Quote:
01-25-2014, 08:46 AM | #17 |
I wussed out and bought the steering kit. Would have preferred to have done it your way.
01-25-2014, 12:35 PM | #18 |
03-16-2014, 11:20 AM | #19 |
| Re: my first cc01!
Aighty, after months of snow, weeks of mud, and much patient waiting the CC is going for his first outing today. Did a little suspension work, new shocks, longer springs and dremmeling on the a-arms for some more travel and steering. Dropped a 60t venom on a 12t pinion got some good low end, pushed with a hobbyking xcar esc. Running some rc4wd 1.55's. I'll let yall know how it goes.
03-16-2014, 07:59 PM | #20 |
| Re: my first cc01!
well all in all not a bad run, kinda short, the wind was pounding like mad. got some good flex but the front springs seem a touch soft. I did notice some slight gear slippage in reverse seems any bind on the front axle will cause gears to slip.
my first cc01! - Similar Threads | ||||
Cc01 | mississippirocs | Testing 1 2 3 | 0 | 09-08-2009 08:03 PM |
