02-23-2014, 03:29 PM | #1 |
Newbie Join Date: Feb 2014 Location: southampton
| My First CC01 build...Or crawler for that matter!
I'm new to the crawling world and want to get into it on a budget so I bought a CC01 Bronco kit. This thread is so that you people can help me take the right direction throughout my build. Well, I ordered the truck and such, it should be here soon, ill keep posted on the build. My overall plan is: Hobbyking radio and reciever XL-5 and stock motor (being replaced in the future with either a GRU or a 55t RC4WD motor) GPM suspension links, I figured it was cheaper than Junfac RC4WD 1.9 White steel rims on 1.9 rock creepers Make my own trail bumper Magic link mod Traxxas Waterproof servo Boca full bearing kit That's really it. I was looking on other forums and people were talking about chopping the "Brick wall"? Someone inform me on this. I presume its the giant plastic block under the bumper. Please inform me of whats the best options for me. I plan on doing medium crawling and a bit of trailing, I'm new to this. |
02-23-2014, 05:48 PM | #2 | |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: My First CC01 build...Or crawler for that matter! Quote:
Looks like you got a solid plan formed so far. I've altered your post with a few things to consider, and a few things I considered myself. I'm new to the CC01, but have LOTS of crawler experience. Just ideas, trying to help with what I've found so far. Last edited by 89redranger; 02-23-2014 at 05:53 PM. | |
02-23-2014, 05:50 PM | #3 |
Not sure why the colors aren't showing, but you can see what I wrote in there. Edit: fixed. Last edited by 89redranger; 02-23-2014 at 05:53 PM. |
02-23-2014, 09:29 PM | #4 |
Thanks for your response! but for the magic link, I plan on using this kind of system so I dont get any sag. I think by putting a spring thats soft enough will be enough for the suspension to flex and return but not too stiff as that will defeat the whole purpose. Edit: Also, what about the steering? any tricks? I heard its terrible out of the box and the GPM one has quality control issues. Last edited by laxboy411; 02-23-2014 at 09:33 PM. |
02-24-2014, 07:15 AM | #5 |
Terrible out of the box? No. Does wear though and develop slop after a while, and the Tamiya 5mm ball ends start to develop some play. GPM kit is a decent upgrade imo with a bit of work - JB Weld or loctite on the ends of the through shaft specifically. Swapping over to Traxxas Stampede rod ends removes the play from the linkages. Something to think about for the future, but not needed right out of the box imo. Stock setup will do fine for a while. |
03-01-2014, 12:04 AM | #6 | |
I'm curious though, how much work does it take to swap in the Traxxas rod-ends? I have a full set sitting here, but couldn't see the body of them fitting without spacing the lower skid/arm mount down off the linkage, or really hacking into the skid. Maybe it's just my eyes... | |
03-01-2014, 06:07 AM | #7 |
They fit. Use button hear screws. It's tight, but it works out. Think I ground a bit for clearance on the GPM kit on one, and bent the steering rod a touch on another due to some other mods I made. Just run it through the full suspension travel and you'll see if you need to make changes, if any. There's 2 kinds of ends in the kit - I try to use the squared off ends on the knuckles, and the more rounded end on the steering rack side if that makes sense. As far as the steering, there is a little play on mine too, I don't even notice it when wheeling. |
03-01-2014, 09:47 AM | #8 |
Awesome. I plan on a little grinding of the GPM kit to raise the chassis end of the tie-rods anyway. As it sits now, the tie-rods run at a slightly shallower angle than the front a-arms, causing a little bump steer. The only other solution would be using a spacer between the rod end and knuckle, which would require more shaving of the stock skid/arm mount.
03-01-2014, 09:56 AM | #9 |
Yes sir, you are exactly right. A 5mm spacer works perfect.
03-01-2014, 01:39 PM | #10 |
Thanks for the confirmation, and more ideas to drain my funds...lol. Done with the thread jack now, time to get to work. Hoping to see some progress on this build as well. Hell, we left him with a good set of ideas to start with...
My First CC01 build...Or crawler for that matter! - Similar Threads | ||||
My first CC01 build...who knows where this one will go. | 89redranger | Tamiya XC/CC01 | 33 | 03-21-2014 06:10 PM |
my cc01 insomnia build | Absurd | Tamiya XC/CC01 | 3 | 10-13-2013 10:12 PM |
My first cc01 build | Takleberry | Tamiya XC/CC01 | 27 | 05-10-2013 03:35 PM |
Anyone with a Maxx crawler,well any for that matter. | Reflection | General Crawlers | 11 | 06-11-2004 09:31 AM |
