04-12-2014, 12:28 PM | #21 |
Pebble Pounder Join Date: Apr 2013 Location: Germany
While waiting for the shocks to arrive, I wanted to take care of the battery opening. Since I will use smaller 3S Lipos, this would only be a source of dirt and mud inside the chassis... Before Some 1mm Polystyrine pieces glued in place and sanded into shape and painted |
04-12-2014, 12:31 PM | #22 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
| Re: My FJ Cruiser
Looks great, I'll need to cut my brick like that, and patch the battery opening as well since I'll be using a smaller 2s lipo.
04-12-2014, 12:33 PM | #23 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Nicely done. Hadn't thought of that.
04-14-2014, 03:13 PM | #24 |
Today, the Proline shocks arrived and what a difference they make... Ultra smooth and the right length... Only mounted them up front for now, still need to build some shock towers in the back. And while I was trying to fit the servo, I noticed that it is a bit too high for the chassis and wouldn't fit without extra spacers. Since the original servo mounts are a bit wobbly anyway, I cut a piece of carbon fibre into shape to provide a much more stable mount and connected it to the sides of the chassis and the single servo mount up front. Last edited by aircooled; 04-14-2014 at 04:58 PM. |
04-15-2014, 05:54 AM | #25 | |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
| Re: My FJ Cruiser Quote:
04-17-2014, 02:08 PM | #26 |
Alright, today I mounted the rear shocks. I didn't want to cut too much off the chassis, so I did it in a similar way to the guys who use Axial shock mounts. Since I didn't have any available, a couple of fiberglass pieces had to do. With the Proline shocks I'm getting some decent flex |
04-18-2014, 03:23 PM | #27 |
Newbie Join Date: Mar 2008 Location: Chino Hills
| Re: My FJ Cruiser
Nice upgrades. This makes me want to get one of these.
04-18-2014, 05:07 PM | #28 |
04-18-2014, 07:57 PM | #29 |
Quarry Creeper Join Date: Jun 2011 Location: Ogden
| Re: My FJ Cruiser
What shaft did you use for the ta06 part? That is a genius mod.
04-19-2014, 12:09 AM | #30 |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
| Re: My FJ Cruiser
Great job on the front shock mounting, using some leftover parts. It acts like a shock mount and chassis brace. I might have to copy that servo mounting plate too, that's a killer piece of work that... |
04-19-2014, 01:02 AM | #31 | |
I just cut a piece of 5 mm steel to lenght, flattened the ends a bit and drilled a 2mm hole for the screws of the Axial shafts Last edited by aircooled; 04-20-2014 at 05:52 AM. | |
04-22-2014, 03:31 PM | #32 |
In preparation for the Electrifly GRU that arrived today, I had to cut the gearbox cover a bit. And to avoid the typical issue with the cover lifting itself under too much torque (which is expected with the 400 Watt outrunner), I drilled through all mount points in the chassis to fix the cover with long M3 screws. And, to make it bullit proof, I added some left over carbon fibre to the cover, to act as very big washers |
04-22-2014, 05:25 PM | #33 |
| Re: My FJ Cruiser
The only advice I would have with all that CF is that if not completely sealed it will take on water and expand and eventually fall apart, unless you dont ever plan on getting it wet. I'm going to order one of these next week |
04-23-2014, 01:07 AM | #34 |
Very good advice for all the readers, thank you! I sealed the cuts with super glue, but usually my cars never get more than a test drive ;) |
04-23-2014, 04:58 PM | #35 |
Still need a adapter for the motor (on order), but at least the rest seems to fit... |
05-07-2014, 04:13 PM | #36 |
Started to work on the steering, to eliminate the GPM stuff (keeping the bearings, of course) Got a 5mm steel shaft, a couple of Pololu alloy hubs that can be fixed with a small socket screw and some alloy spacers. One of the hubs had to be trimmed a bit for clearance. And installed Still need to build some arms on the top and bottom to mount the tie-rods |
05-07-2014, 10:18 PM | #37 |
| Re: My FJ Cruiser
I'm really enjoying this build. Great ideas and so clean!
05-07-2014, 10:41 PM | #38 |
| Re: My FJ Cruiser
I'm liking your fresh approach on the steering, interested to see the end result...
05-09-2014, 10:36 AM | #39 |
| Re: My FJ Cruiser
This is looking really good!
05-09-2014, 06:08 PM | #40 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
| Re: My FJ Cruiser
Nice looking steering mod. Very curious to see if the modded steering components change the bump steer.
My FJ Cruiser - Similar Threads | ||||
fj cruiser ? | rock and roll cowboy | Tamiya XC/CC01 | 2 | 12-19-2011 11:01 PM |
My new cc01 cruiser with my scx10 cruiser | gymjunkie23 | Tamiya XC/CC01 | 10 | 07-28-2010 01:03 AM |
