Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: Stock Shocks
Old 07-13-2014, 10:29 AM   #1
Default Stock Shocks
Hi,
New here and new to CC01 got it last week.
I find the suspension to stiff, the truck bounces a bit.
Can anything be done to the stock setup or should I be looking at new shocks.
Im looking at new tires and wheels as well, like the Junfac ones.
Want to smooth out he ride and make is look more scaled realistic looking when driving at slow speeds, worked out I should have locked the diff when building but I have a bearing set on order, once I put them in I shall lock the rear diff.
Cheers
raymate is offline   Reply With Quote
Old 07-13-2014, 12:28 PM   #2
Stock shocks can work well. I filled mine with some 55wt silicone and they worked flawlessly. Travel is a little limited, but if you're going for scale, they're perfect.
monkeyracing is offline   Reply With Quote
Old 07-13-2014, 02:26 PM   #3
Default Re: Stock Shocks
Not knowing much about oil, I would assume this is thinner than the Tamiya stock supplied oil and I should see a softer ride.
Was wondering what the springs play in this it seems two different type are used in the kit front and back, again to me they seem to stiff.
Yes Im trying to get scaled look
Old 07-13-2014, 03:24 PM   #4
Or do what I did...
Use Axial SCX10 shocks. It requires drilling through the tub chassis, but it's worth it...
I get major flex
Louisbaby is offline   Reply With Quote
Old 07-13-2014, 04:25 PM   #5
Usually stock shock oil is in the 25-35wt range, lighter than the suggested 55wt oil. Does your truck have oil or friction dampeners? I am assuming oil based on your earlier comment. If there is any binding in the shock it will give a very firm ride. My stock shocks/springs were way to soft for my setup. I am currently running shocks from AsiaTees 70mm aluminum bodied for about $13 a pair. I like them they even have threaded bodies for adjustable preload.
lonleycreeper is offline   Reply With Quote
Stock Shocks - Similar Threads
Hot racing shocks or stock axial shocks Qcustomz 1.9 Scale Rigs 0 01-28-2013 03:30 PM
opposite shocks or stock shocks Jamesarnone Newbie General 1 04-01-2011 01:26 PM
Are the losi shocks shorter than stock shocks ?? im2tall Venom Creeper 3 02-05-2010 12:33 PM
