10-17-2014, 03:27 PM | #1 |
Rock Stacker Join Date: May 2013 Location: The Bridge
| new shocks? nitrocharger 's |
10-17-2014, 04:55 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: new shocks? nitrocharger 's
If you have had experience with the standard RC4WD Ultimate Scale shock, then you'll know how these will perform. They're the exact same construction, just a different color. They are 70mm eye to eye. |
10-17-2014, 07:26 PM | #3 |
| Re: new shocks? nitrocharger 's Thanks for the input, so you're suggesting i go with the 70mm version?
10-17-2014, 07:46 PM | #4 | |
| Re: new shocks? nitrocharger 's Quote:
Being that they're very springy as they come out of the package, I always cut my springs down about 3-5 coils so that they can settle to the right ride height and still have the up/down travel needed for them to work. | |
10-17-2014, 07:56 PM | #5 | |
Ah okay, I'm asking because it's for a CC01 chassis and the stock ones are 70mm i don't want anything to bind if i go too long. I may go with 80mm and try your coil trick though. Thanks | |
10-18-2014, 05:33 AM | #6 |
Rock Stacker Join Date: Aug 2014 Location: Perth Australia
I Have 70's on the front of mine and 90's on the rear a mate of mine got 80's all round and has lost travel in the front (not much) but I still get better travel on mine as his stops a few millimetres before mine does, and I installed 90's on the rear as my unimog body can handle hiding the chassis up inside the body and get better performance than 70mm shocks shot of the rear and the front I will be attending a comp tomorrow and I can let ya know how it performs and I haven't cut the coils on these as the front ones are very soft and the rears are harder but still manageable Last edited by steamboatbob; 10-18-2014 at 05:34 AM. Reason: extra info |
10-18-2014, 07:45 AM | #7 |
Newbie Join Date: Sep 2014 Location: London
Std unmodified front suspension can't even get the full extension on the 70mm dampers, so stay with 70mm. Modified can use the full 70mm. Rear can use longer ones, 80mm definitely OK, maybe 90mm, but I'm using 80mm on mine, with the Tamiya drop links. |
10-20-2014, 04:03 PM | #8 |
| Re: new shocks? nitrocharger 's Quote: |
10-20-2014, 04:03 PM | #9 |
| Re: new shocks? nitrocharger 's Thanks man, I bought a pair of the 70s for the front, so my rear is still stock right now, but i too have the drop links so i may stretch for the 80s later on. Thanks a lot
10-21-2014, 07:33 AM | #10 |
no probs. and I don't use the drop links anymore as you lose too much traction at the rears when they do drop. and I used them at a comp on the weekend just gone and they performed very well you just have to remember that they do not need to be filled with oil they only require a very small amount of oil in them to lubricate the seals. If I can find a picture of my chassis without the body on it I shall post it here for you but my unimog is in bits atm as it needs a clean and had a very dramatic CVD fail at the comp (I bent a pin which in turn somehow destroyed my steering links ) Last edited by steamboatbob; 10-21-2014 at 07:35 AM. Reason: added info |
10-22-2014, 09:44 AM | #11 | |
10-22-2014, 11:06 AM | #12 |
There are two schools of thought re drop links in 1:1 off roading, which I've done a bit off. Not used drop links though, as they're not a good idea when used on road. Some say without any spring pushing the wheel down, you won't get any traction, so a waste of time. Possible. Others say that at least the tyre will be in contact with the ground and it will have the weight of the wheel and tyre to help give traction. Also possible. |
10-24-2014, 06:40 AM | #13 |
yes I agree slimjim but after a fair bit of trialing I found that the rears had a lot less traction on my cc-01 when the extension links were installed and the rims I have a very heavy but on a different setup it could work. and marcod I had some shock oil about but I only put a few drops in each shock as I said its just to lubricate the seals so any shock oil would be good. |
10-25-2014, 11:44 AM | #14 |
Thanks, it's nice to have some real life feedback. Although mine's not a shelf queen, it doesn't get much use.
10-25-2014, 01:09 PM | #15 | |
Just got the shocks in today, they're very precise and smooth. Gotta test them on a trail now! Can be seen at my build thread here Tamiya CC01 Subaru Brat Last edited by marcod13; 10-28-2014 at 07:58 AM. | |
Tags |
nitrocharger, old man emu, rc4wd |
new shocks? nitrocharger 's - Similar Threads | ||||
RC4WD Old Man Emu Nitrocharger Sport Shock by ARB | Rckcrwlr | Scale Accessories | 13 | 09-26-2013 04:42 AM |
