10-22-2014, 10:30 AM | #1 |
Newbie Join Date: Oct 2014 Location: Clarksville
| Pinion Gear
What pitch is the pinion and spur on the CC-01? Cant seem to find one that will fit. Trying to gte more torque.
10-22-2014, 10:42 AM | #2 |
| Re: Pinion Gear
Metric 48p. 16t or 20t. (Stick with 16) Robinson Racing Metric Pinion Gear 16T (RRP1116) | RC Planet |
10-22-2014, 10:56 AM | #3 |
| Re: Pinion Gear
using 16 now and all i get is speed and not enough torque Last edited by TamiyaGuy007; 10-22-2014 at 11:25 AM. |
10-22-2014, 03:11 PM | #4 |
Quarry Creeper Join Date: Feb 2011 Location: Forbestown, CA
| Re: Pinion Gear
if you check the builds here and other post asking how to slow down or get more torque the best answer is the simplest, Using a Gear guru from hpi, Rc4wd, or just a old electric drill all of these work with a little modification. RC4WD - Welcome Gear Reduction Unit hope this helps |
10-23-2014, 04:26 PM | #5 |
Newbie Join Date: Sep 2014 Location: London
| Re: Pinion Gear
Has anyone tried an 80T motor?
10-23-2014, 11:39 PM | #6 |
| Re: Pinion Gear
no I use the axial 55t motor
10-24-2014, 03:48 PM | #7 |
Newbie Join Date: Sep 2012 Location: duncan
| Re: Pinion Gear
i had an 80 turn in mine for a bit and it had no torque.
Pinion Gear - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
pinion gear | zero1 | Axial SCX-10 | 4 | 03-28-2012 09:38 AM |
Pinion gear | meshal | Team Losi Comp Crawler | 4 | 01-10-2012 02:09 PM |
