Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: straight axle swap questions
Old 12-14-2014, 04:27 PM   #1
Default straight axle swap questions
I'm wanting to straight axle swap my pajero I found some scx10s for a cheap price. Now would it be better to swap to straight axles or just sell it
nate3923 is offline   Reply With Quote
Old 12-14-2014, 04:43 PM   #2
Default Re: straight axle swap questions
If you want a unique rig then swap it
old man 52 is offline   Reply With Quote
Old 12-14-2014, 05:11 PM   #3
But will those axles fit
Old 12-14-2014, 05:24 PM   #4
You should just put a tlt axle up front , the gear ratio is the same.
Old 12-14-2014, 05:28 PM   #5
Axials are too wide to look scale imo
slow1500 is offline   Reply With Quote
Old 12-20-2014, 10:20 PM   #6
Oppan Gangnam Style
chino63's Avatar
The TLT is 2.67:1 and the CC01 is 1.8:1 if I remember right.
chino63 is offline   Reply With Quote
Old 12-20-2014, 10:27 PM   #7
Oops my bad.
straight axle swap questions - Similar Threads
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits LetsHandleit Axles, Trannys, T-case 41 06-24-2012 07:57 PM
RC Axle Master's Straight 4340 Chromoly Straight Axles Cruzin Illusion EnRoute Berg 48 08-29-2009 07:07 PM
Hot Racing rear straight axle kit or stock Axial straight axle lockout? jmbones Axial AX-10 Scorpion 36 05-28-2008 05:28 PM
