![]() | #1 |
Pebble Pounder Join Date: Nov 2005 Location: south jersey
My current setup is 1.55 mtz's, 3s, 85t brushed, and the gpm spur with the the small pinion. Original gearing was 16/80. Speed was perfect. I had a spur issue and replaced with the gpm stuff. much stronger but now I think its too fast. I used the small pinion in the gpm kit so now its 13/6? dont know the spur count. On top of that I want to swap to a 1.55 mud thrasher which is taller than my mtz's. How do I gear down?
![]() | #2 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
If you are already using the smaller of the two pinions the only thing I know of to do is install a Gear reduction unit.
![]() | #3 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
Sol unless you go to a reduction unit. Rc 4wd makes 2,3,4:1 bolt in planetary reductions Sent from my iPhone using Tapatalk |
![]() | #4 |
Wow, sorry to not get back to this sooner. What I was trying to say is which gear reduction do I go with to get back to my original setup?
Motor/gearing? | remington7 | Team Losi Comp Crawler | 4 | 12-09-2014 11:35 AM |
Gearing or motor? | 6sharky9 | Newbie General | 9 | 08-11-2013 07:05 PM |
20t motor and 45t motor gearing question? | rcstrike | Newbie General | 1 | 11-16-2011 03:40 PM |
motor gearing | grizz | Electronics | 2 | 02-26-2008 04:41 PM |
Motor Gearing | crawler nate 66 | Electronics | 0 | 01-28-2008 05:22 PM |
