Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: Tire seize on your fj40
Old 04-05-2015, 07:07 PM   #1
Default Tire seize on your fj40
Hei guys.
How big tires have you fitted on your FJ40 without it looking retared?
Pls post some pics of your rig
I have some brand new RC4WD Mickey Thompson 1.55 Baja Claw TTC Tires 114mm tall.
Shoud i order some smaller tires wile i wait for my new rig?
Rcdood is offline   Reply With Quote
Old 04-06-2015, 12:33 AM   #2
Default Re: Tire seize on your fj40
If your looking for cheap scale size tyres I would recommend Fastrax Kong's.
They come in two sizes, 90mm and 96 mm and slightly wider than standard. They also preglued with foam inserts.
These are what I use on my FJ Cruiser and they work perfectly and look good too.
BTaylor20 is offline   Reply With Quote
Old 04-06-2015, 04:45 AM   #3
Thanks for the advice buddy!
Ive already got RC4WD Mud Thrashers 1.55 wich is 95mm (thats on my pajero chassi).
Was hoping i coud go abit bigger on the fj40 for ground clearence
Old 04-06-2015, 07:11 AM   #4
I try not to go above 100mm in diameter. You'll start having to cut up the chassis if you go larger.
OSRC is offline   Reply With Quote
Old 04-06-2015, 09:32 AM   #5
Ok, thanks for the tip
Have the perfect tire in mind then
RC4WD Rocky Country 1.55 Scale Tires (ok, they are 104mm, but that shoud be workable).
Old 04-06-2015, 11:03 AM   #6
Btw anyone got any exp with this rollcage combo?
Unsure of quality and howe scale it accually is..
New Matal Luggage Tray Stair Set for Tamiya CC01 CR01 Toyota Land Cruiser | eBay
Tire seize on your fj40 - Similar Threads
tire poll...im gonna let rcc vote my next tire gsrcivic Tires and Wheels 57 10-22-2013 07:05 PM
Pin Tire with Comp Tire Sidewall - How To Write up Kraqa Tires and Wheels 16 08-27-2010 11:55 PM
high lift tire and hummer tire comparison luis Tires and Wheels 2 01-11-2008 06:56 PM
Axial 2.2 Rock Lizards Tire, tire test rockwerks Tires and Wheels 1 05-27-2007 03:02 PM
