10-14-2015, 01:36 PM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: newark
| help needed
i just got my first cc-01 . i bought a freelander . just rolling on the ground i have 4wd as soon as i try to climb something i get a pop and loose rear drive any ideas on this one i have taken it apart several times .
10-19-2015, 10:18 PM | #2 |
Quarry Creeper Join Date: Oct 2004 Location: Beckley
| Re: help needed
When mine did that it turned out to be two of the internal gears pushing apart. Hold the truck still and apply power and see where the noise is originating. One you find the culprit just shim it a little tighter and you should be good. Also check to see if any set screws have loosened, sometimes it's something that silly that gives you trouble. Good luck and welcome to the CC01 family!
10-24-2015, 03:01 PM | #3 |
| Re: help needed
thank you elmo I appreciate the reply im going to get back to it as soon as I finish my wroncho im always changing something on it
12-02-2015, 06:06 AM | #4 |
Newbie Join Date: Dec 2015 Location: Isle of Man
| Re: help needed
I have had the rear diff internal screws loosening and losing the drive a couple of times. so i would check those as well.
12-05-2015, 06:00 PM | #5 |
| Re: help needed
thank you , I had to shim a trans gear and then it was fine .
help needed - Similar Threads | ||||
just what i needed | xztheericzx | Chit Chat | 3 | 11-05-2007 06:46 PM |
