12-03-2015, 02:41 PM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
| Front wheel binding?
I just built a 425 Unimog and I'm having issues with the front wheel binding if I tighten the wheel nut down. It spins freely when the nut is loose, but then so is the wheel. This is happening on both front axles. I was using bearings and even swapped in the kit bushings to see if it would make a difference but it does the same thing.. Anyone know what the problem is?
12-03-2015, 06:44 PM | #2 |
Pebble Pounder Join Date: May 2006 Location: willows
| Re: Front wheel binding?
Maybe the hex is hitting and putting pressure on it causing the bind.
12-03-2015, 07:04 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
If I remember right, the front and rear hexs are a little. Try switching them around and see if they still bind.
12-03-2015, 09:29 PM | #4 |
RCC Addict Join Date: Oct 2007 Location: Long Island-Land of one batch of rocks in Sag Harbor and at least one fellow crawler
Yes the front and rear hexes are slightly different. Swap them out.
12-04-2015, 01:47 PM | #5 |
You guys are geniuses.. That was exactly my problem! I totally did not realize that they were different.
12-04-2015, 02:48 PM | #6 |
Happy to hear it was a simple fix
Front wheel binding? - Similar Threads | ||||
Front Driveshaft Binding | snakeman | Kyosho Crawlers | 6 | 12-04-2015 01:19 AM |
front uni's binding??? maybe | Wilt | Axial Wraith | 2 | 06-21-2015 09:11 AM |
Front Left Wheel Binding When Turning Right... | Gimpdiggity | Axial SCX-10 | 30 | 06-08-2012 10:24 PM |
Front axle binding | rottenbelly | Axial AX-10 Scorpion | 7 | 01-15-2009 07:16 PM |
