01-25-2016, 12:42 PM | #1 |
Quarry Creeper Join Date: Jan 2008 Location: san jose
| double joint front driveshaft?
I was wondering if anyone had successfully retrofit a double universal joint front axles into the chassis? My rig has been lifted to the max and there is a bind on the shaft which causes the suspension to dip when driving so the shaft could rotate thru the joint. I seen some road cars with the double joints and at full turn wheels do not hop. Maybe a good mod for the car when front is maxed out on lift. |
07-20-2016, 12:45 PM | #2 |
| Re: double joint front driveshaft?
Ok so i did some research and found M05 axle shaft is same length as the CC01. I ordered a set of M05 double cardan shaft set along with some 42mm and 40mm joint shafts for the cardan axles. The cc01 hubs require big bearing for the back end. So I sent in a drawing to 3d print up some spacers to fit the smaller bearing that comes with the cardan axles. I suspect I may need to make new hub carriers also. Pics and results to follow. Hopefully these will not bind up. |
07-24-2016, 04:55 PM | #3 |
Quarry Creeper Join Date: Oct 2004 Location: Beckley
I had at one point mocked up a set of 3Racing Sakura D3 wide angle shafts into my CC and gave up before even checking the shaft length due to the bearing size difference. I would love to see the spacer you are 3d printing to see if this is possible with the shafts I have. Keep us updated!
07-26-2016, 09:16 AM | #4 |
Bah the reducer that I had made had wrong dimensions. I measure the wrong bearing. And with the bearing that fits the axle , its too small for the hub. So there goes the retrofit. Looks like I only have 42mm joing shafts which were too long. I think 38-40 would be perfect for the car. |
07-26-2016, 04:14 PM | #5 |
Tamiya TA knuckles drop right in, they use 2 5x11 bearings per side if that helps. Gives you 10mm more width per side though. TowerHobbies.com | Tamiya Front Upright Car TA01 (2) |
07-26-2016, 08:39 PM | #6 | |
| Re: double joint front driveshaft? Quote:
03-10-2017, 11:54 AM | #7 |
i decided to revisit this. I ordered some M05 and FF03 uprights and hubs. Trying to see how they fit and then 3d print a new lower arm to see how it all goes together.
03-17-2017, 09:32 AM | #8 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
Not sure if this has the info you're looking for, but an awesome source for the CC01 anyway. CC01= TA02 and TA03 Parts Compatability CONFIRMED - Scale 4x4 R/C Forums |
double joint front driveshaft? - Similar Threads | ||||
u-joint popping out of driveshaft | TxCruzr | General Crawlers | 20 | 01-28-2017 03:40 PM |
Double CVD joint? Spec-R? | sweli | Non Crawler RC's | 3 | 05-29-2011 07:01 AM |
which driveshaft to get ??? 97mm joint to joint | DAN8701 | General Crawlers | 0 | 05-02-2010 12:25 PM |
building a double cardigan joint........??? | twisted84toyota | General Crawlers | 8 | 02-18-2007 10:00 AM |
Driveshaft slip joint travel? | Reflection | General Crawlers | 16 | 06-12-2004 08:48 PM |
