Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: New CC-01 owner help
Old 06-07-2016, 12:44 PM   #1
Default New CC-01 owner help
Hi Guys,
I recently got back into RC with a CC-01.
I got a GPM Steering kit, GPM 4-link set and GPM aluminium servo horn.
And I bought some aluminium 1.9 beadlocks and 90mm tyres.
Now I run into a few issues.
First of all, the steering, I barely have a turning radius with it.
The knuckles hit the hubs pretty fast.
Next is the battery, I have a few standard 2s hardcase packs, according to the measurements before ordering and those of the CC-01 battery tray I found they should fit after squaring out the battery tray of the CC-01.
I did that, but the lipo's are still only a hair too big to fit, what else can I do to make them fit?
I found that if I do not place the electronics tray in the car and remove the part of the chassis where you normally slide the battery under to mount it in the chassis, I can probably fit my lipo's with some velcro or something.
But won't that give too much flex to the chassis?
Yonzariq is offline   Reply With Quote
Old 06-08-2016, 09:36 AM   #2
Default Re: New CC-01 owner help
I changed my electronics mounting plate to accommodate a 3S 3000 mah battery
Hard to make out, but I put a piano hinge on a flat plate and raised it about 1/2 inch.
Opened plate:
PLate from top of unit:
I drilled a hole in a screw that sticks through the plate and used a body clip to hold it closed.
Some soft foam to cushion the battery.
If your battery is too long, a different approach is needed. My battery was short but thick.
Hope this helps..
Chumley54 is offline   Reply With Quote
Old 06-09-2016, 12:37 AM   #3
Thanks, it does give some nice help
But indeed my battery is too long.
It's a standard 5000mah 2s squared hardcase.
I'll try to take some photo's tonight to show what I mean
Old 11-14-2016, 01:56 AM   #4
Totally forgot this thread...
But I got the battery to fit in, dremeled out the chassis a bit more, removed the electronics plate and placed the ESC somewhere else
Glued 96mm Boom Racing tires on the stock wheels,
Car runs great now, except there is still a ton of slop in the steering...
The rod-ends of the links have a lot of slop, and the knuckle/c-hub have a lot of play in them, so I have to find a way to reduce that.
And remove the brick and create a skidplate in place for it some time
Old 11-15-2016, 06:00 AM   #5
if you buy cvd axles and cut some plastic you and get a better turning radius.. but not recommended with the Dog bones..
jeepgeek2002 is offline   Reply With Quote
Old 11-15-2016, 07:02 AM   #6
Thanks for the tip!
Ordered a better ESC and 55t motor first as stock on 2s is just way too fast.
Now I first want to minimize the steering slop as much as possible before buying CVD's
Old 11-15-2016, 08:31 AM   #7
Get the aluminum steering assembly and that will get rid of the slop
aiden102408 is offline   Reply With Quote
Old 11-15-2016, 01:31 PM   #8
Already got the GPM kit, slop is in the rod-ends and between the knuckles and c-hubs
Old 11-15-2016, 01:56 PM   #9
I dunno then ... I'm new to the cc01 chassis
I have a bronco and a unimog and haven't ran either one lol
Old 11-23-2016, 12:23 AM   #10
First off if you havent already, cut the nipples off the chubs. This will give a little more steering angle and still be within range of the dbones. As far as slop goes you can try to shim here and there but i just plan on going with full alu up front and hope for the best lol.
moondaddy is offline   Reply With Quote
Old 11-23-2016, 01:30 AM   #11
yeah, doing the same right now...
Ordered a lot of alu front steering parts haha
New CC-01 owner help - Similar Threads
XJ owner out-asshole parks Corvette owner..... STANG KILLA SS Chit Chat 18 09-30-2014 06:20 PM
New owner! CTPATRIOT Tamiya Bruiser 1 11-26-2012 04:38 PM
New cc owner joe-oh Tamiya XC/CC01 1 01-22-2012 07:58 AM
New owner. mally General Crawlers 16 02-05-2007 05:51 PM
New XC owner; not many here, but just saying HI and some ???. chinook General Scale Talk 2 08-10-2006 01:03 PM
