1.9 wheel/tire on CC01 Looking at a CC01 Bronco and I want to put 1.9 Gearhead slotted mags on it.This project is to be a close replica of the Bronco in the Eiger Sanction. Any advice? |
Re: 1.9 wheel/tire on CC01 If you don't mind the glue on wheels, the 1.55 version is perfect for the size of the truck. If you stick with 1.9, tires under 100mm in diameter are your best bet. Anything larger rubs the chassis and/or requires serious body trimming. Good luck! |
Re: 1.9 wheel/tire on CC01 Thanks, I wouldn't be crawling with it just drive it around on occasion. |
