Go Back   RCCrawler.com Bulletin Board > Vendors > TCS Crawlers - The Crawler Store
Thread: New 23mm Adapters for Clod2Maxx adapters - $15
Old 01-22-2006, 11:20 PM   #1
The Wheels Keep Turning
kevinlongisland's Avatar
Default New 23mm Adapters for Clod2Maxx adapters - $15
14mm to 23mm Hex Adapter kit - Use for Pro-Line 40 Series Commando Bead-Loc and Pro-Line 40 Series 23mm Cheyenne Chrome Wheels. $15/set of 4
This inexpensive kit allows you to install 23mm hex rims onto your Clodbuster axles when used in conjunction with the Clod to Maxx adapters (Part # CLD2MX)(Thunder Tech #DEL-CB03). You can run Pro-Line 40 Series Commando Bead-Loc and Pro-Line 40 Series 23mm Cheyenne Chrome Wheels with these adapters. Includes 4 each 14mm to 23mm hex adapters and 4 each circular rings. These work in conjunction with Part # CLD2MX (Thunder Tech DEL-CB03), so you must purchase or already own Part # CLD2MX to use these.
kevinlongisland is offline   Reply With Quote
Old 02-09-2006, 11:03 PM   #2
Mad Hatter's Avatar
Will this set up have enough width to accomodate the 23mm Cheyenne Beadlocks and XL Moabs?
Mad Hatter is online now   Reply With Quote
Old 02-09-2006, 11:57 PM   #3
I believe it will, but that also depends on your truck. But I know it works with the regular 40 series beadlocks, and I believe the XL setup has even more clearance.
Old 02-14-2006, 12:28 AM   #4
OCCUPY RCC!
dezfan's Avatar
Just ordered a set of your 14mm to 23mm adaptors!
dezfan is offline   Reply With Quote
Old 02-14-2006, 12:32 AM   #5
Thanks for your order. Let me know if they work with those adapters. They are rcguy adapters?
Old 02-14-2006, 05:01 AM   #6
Hi, I'm looking at buying both these items 14mm to 23mm Hex Adapter kit
And
CLD2MX
How much for shipping to the uk with insurance/ and without insurance?
Thanks stuart.
slipping_side_ways!!- is offline   Reply With Quote
Old 02-14-2006, 08:54 AM   #7
And
CLD2MX
Thanks stuart.
I'm not really sure of the additional cost of insurance. Those items are light so there is no additional fee to ship them internationally. Just add them to the cart and pay. Thanks.
Old 02-14-2006, 11:41 AM   #8
OCCUPY RCC!
dezfan's Avatar
Yes they are rcguy adapters, I'll be sure to let you know!
Old 02-17-2006, 09:10 PM   #9
OCCUPY RCC!
dezfan's Avatar
Originally Posted by dezfan
Got my adaptors today, thanks! I'm still waiting on my 40 series. I'll keep you updated!
Pics up.
Old 02-18-2006, 12:22 AM   #10
It looks like the adapters will work with rcguys clod to max adapters then. Let us know after a week or so of use how they hold up with the rcguy adapters. Thanks for the info.
Old 12-23-2006, 09:12 AM   #11
would you take a money order for them, and how much would shipping be
CRUSHER1 is offline   Reply With Quote
Old 12-24-2006, 08:36 AM   #12
pm sent
Old 04-26-2007, 05:35 PM   #13
So these will work going from my tmax drive hex to a 2.2 drive hex?
smallscalekrawler is offline   Reply With Quote
Old 04-27-2007, 03:12 PM   #14
Actually, I believe your tmaxx drive hex is the same as a typical 2.2 wheel (14mm hex). So you won't need an adapter.
Old 04-27-2007, 05:59 PM   #15
Its bigger.
Old 04-28-2007, 08:35 AM   #16
Its bigger.
I don't know of any adapters that go down in size. But you should be able to find a hex that fits on there that is the same size as the 2.2 wheels. See if your local hobby shop can find something for you.
You may edit your posts
