| | #1 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| ![]() ![]() Use our advanced shopping cart software to guide you through the process of building your very own customized Rock Crawler! __Build A Truck__ Which chassis kit would you like? Do you need Clodbuster Axles? Select your lockers Do you need bearings? Select your motor mounts Select your front motor Select your rear motor Select your front pinion Select your rear pinion Select your speed controller Select wire for your motors Select your front shocks Select your rear shocks Select your shock oil Select Front Servo Select Rear Servo Select your servo extension Select your front servo saver Select your rear servo saver Select your front rims Select your rear rims Select your front tires Select your rear tires Select your wheel adapters Select your body Select your body posts Select your battery Do you need a charger? Select your radio system |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Mar 2006 Location: Asheville,NC
| Thats a great idea for beginners |
| Thread Tools | |
| Display Modes | |
